Kiats
Squeezing in some late Friday night vocal music on QQMusic, on the Obsidian and UM Fusang customs. Long week draws to an end.
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
![F3D6C8B1-8549-4AA5-9B9F-EC7EDC32F29A.jpeg F3D6C8B1-8549-4AA5-9B9F-EC7EDC32F29A.jpeg](https://cdn.head-fi.org/a/11648747.jpeg)
Looks great!Here's my happy streaming solution right now. DX240 -> P6 Pro
FS isn't bad out of 240 but pairs sooo well with P6 Pro
Yeah, honestly phone works fine... I just keep my audio chain separate from my phone unless I have to...Looks great!
Honestly, when Apple makes their Bluetooth lossless, I don’t see myself needing any Android-based dap at all.And even now the Bluetooth/usb dac options are already pretty solid.
That's why I didn't trade in my last iPhone.Yeah, honestly phone works fine... I just keep my audio chain separate from my phone unless I have to...
Looks great! What kind of OTG cable is that? I've tried my P6P usb Dac with my Samsung S9+ and it's kind of muddy and the volume control still works, so I think the cable I am using isn't correct/isn't otg. USB C to USB C is what I need.Squeezing in some late Friday night vocal music on QQMusic, on the Obsidian and UM Fusang customs. Long week draws to an end.
It’s actually a cable I got off Taobao. Interesting that you have that issue with the USB DAC. Volume control does still work on mine as well.Looks great! What kind of OTG cable is that? I've tried my P6P usb Dac with my Samsung S9+ and it's kind of muddy and the volume control still works, so I think the cable I am using isn't correct/isn't otg. USB C to USB C is what I need. Any suggestions?
Thanks! Yeah, I use the BT option quite often and it works great. Looking for a wired solution for 100% audio quality when I'm not moving around.It’s actually a cable I got off Taobao. Interesting that you have that issue with the USB DAC. Volume control does still work on mine as well.
Perhaps try the DDHifi USB C to USB C cables. Amazon sells them.
Alternatively, perhaps you can try the BT functionality of the P6Pro. Works very nice especially with android devices which would have LDAC. The photo below is with my work Samsung S21.
sorry. you meant volume control on the phone. that would be disabled. at least it is on my iDevices which I use cabled for USB C. the volume still works on the P6Pro though.Thanks! Yeah, I use the BT option quite often and it works great. Looking for a wired solution for 100% audio quality when I'm not moving around.
So you have also have volume control on your Android phone with OTG audio out? Weird. I can plug my Android into my Focusrite Interface which powers my studio monitors and I get direct audio out, no volume control, so I know it "can" do it.
EDIT - I tired using UAPP and selecting Bit Perfect output and now it works great - volume control is disabled. Using normal USB C cable. Is there any reason to buy an "Audiophile" USB cable? I'm a total cable believer, but pure digital signal, not sure. Maybe worth a try?
I once bought a $700 usbc otg cable and it makes ABSOLUTELY no difference compared to my $20 otg cable. So expensive lesson learned, expensive digital cables is a no go.Thanks! Yeah, I use the BT option quite often and it works great. Looking for a wired solution for 100% audio quality when I'm not moving around.
That's because digital cables have chips on both ends and data is integrity verified during the transfer unlike analog cables. While cable quality is still important to ensure no loss occurs during transfer, this is usually something to watch for if the cable is shoddily made or extended lengths.I once bought a $700 usbc otg cable and it makes ABSOLUTELY no difference compared to my $20 otg cable. So expensive lesson learned, expensive digital cables is a no go.![]()
