Interesting machine from Luxury n Precision
Nov 4, 2021 at 5:21 PM Post #2,041 of 4,416
Eh...I ran my friend's mest mkii on low gain at vol 7...and the annihilator at 9 low gain.
Now I'm wondering my unit has excessive power or is everyone else blowing their ears out 🤔
Which firmware are you on? I thought L&P change the volume scale with 1.0.0.7. At night, I used to listen with Traillii, low-gain, vol 1-2. Around 10 during the day. Now I get few clicks at night and up to 15-20. Maybe my ears have gone bad :scream:
Nov 4, 2021 at 5:40 PM Post #2,042 of 4,416
I received it 1.0.0.7 out of the box. Listening volume around 65-75db depending on how engaging I want to be to my music.
Nov 4, 2021 at 6:10 PM Post #2,043 of 4,416
Good for you! :beerchug:
Nov 4, 2021 at 8:29 PM Post #2,044 of 4,416
Another P6 Pro rookie question. I have a lighting to USB C cable and would like to stream Roon to an iPhone to the P6 Pro. What settings do I need to change on the P6 Pro to make this work and what audio zone in Roon should I select. I'm sure this is basic stuff but I'm still learning. Thanks.
Nov 4, 2021 at 9:11 PM Post #2,045 of 4,416
Before you make the connection, change the following.
System settings -> Advanced -> USB Connection mode -> USB Audio
System settings -> Advanced -> USB Power Supply -> Self Power Supply
Nov 4, 2021 at 9:23 PM Post #2,046 of 4,416
audio zone should be your iPhone. Roon will not recognise your P6Pro, only the iPhone as Roon endpoint.
Nov 4, 2021 at 9:25 PM Post #2,047 of 4,416
hmm... should I be worried about my listening volume level too... but I've been pretty consistent with the volume. With the efficient BA based FitEars, it does tend to be rather low on low gain on the P6Pro. ;)
Nov 5, 2021 at 2:32 AM Post #2,049 of 4,416
Nov 5, 2021 at 11:11 AM Post #2,050 of 4,416
The IPad Mini 6 has arrived! Listening to Apple Music via the LP6 into the UM Mest 2. Nice way to spend a Friday evening. :)
Nov 5, 2021 at 8:36 PM Post #2,051 of 4,416
Early Saturday morning listening. Lovely start to the weekend. :)
Nov 5, 2021 at 9:18 PM Post #2,052 of 4,416
Is that the SPDIF port lit up green? When does the light turn on?
Nov 5, 2021 at 9:47 PM Post #2,053 of 4,416
yes it is. Together with the little light. Because the LP6 does draw power from the device when it is connected via USB, red would indicate that it is charging, green is when it is fully charged. You will see the same colours lighting up when you are charging the LP6.
Nov 5, 2021 at 11:05 PM Post #2,054 of 4,416
Thank you! I didn't know LP6 had those lights.
Nov 6, 2021 at 12:25 AM Post #2,055 of 4,416
