- Feb 21, 2007
**** that! Had to respond just to say that.I was just told by MusicTeck that the croc case for P6Pro will cost $1100. No thanks.
Yes, I found this incredibly frustrating, but thankfully someone earlier mentioned sdsorterThe thing I do not understand and do not know a solution to is that if I browse the SD card (with folders for each artist), they appear random, but maybe in order of time when added to the card. Similarly, when I look at the songs of one album, they are not ordered by title # but appear random, even though the title 1 is shown.
If anyone has any tips about that, I would appreciate it.
Thank you for pointing me to this. Unfortunately it is a Windows and Linux only program. But maybe I can find something that works on a Mac. Much appreciated.Yes, I found this incredibly frustrating, but thankfully someone earlier mentioned sdsorter
More fiddly micro-managing of your library to work around the shortcomings of L&P's OS, but worth it for the upside benefits of the P6Pro.
Run this script in the top level directory of your music and make sure you confirm with a "y". It will reorder them so they are right. You will also need to re-run every time you copy new music.Thank you for pointing me to this. Unfortunately it is a Windows and Linux only program. But maybe I can find something that works on a Mac. Much appreciated.
This is exactly what I was looking for. Thank you so much!Обновления прошивки можно найти здесь:
https://shop.musicteck.com/pages/lp-firmware-upgrade
Это довольно просто на ПК с Windows. Вам просто нужно подключить его через USB к ПК и сбросить файлы в каталог DAP, как указано здесь, и перезагрузить LP6TI, и он обновит его. Что касается MacBook, я никогда не пробовал. Не уверен, что вы все еще можете подключить его и увидеть диск на DAP. Если вы можете и сбросить файлы туда, это должно быть довольно просто. Если нет, то вы можете попробовать одолжить чей-нибудь ПК с Windows на минуту или две, чтобы просто перенести файл.
В новой прошивке есть полоска заряда батареи и лучшая поддержка некоторых музыкальных файлов, так как раньше она просто не воспроизводила некоторые форматы файлов. Я также почувствовал, что они настроили DAP, чтобы лучше оптимизировать мощность, используемую для продления срока службы батареи.
