rickcr42
Are YOU talkin' to me?
- Jun 21, 2001
that would be a severe case.You can have a cold joint with good mechanical integrity but p*ss poor electrical integrity.There ARE degrees to this as in all things.
i worry more about the ones that are not so obvious that the part pulls loose.The one is easy .the "hidden" ones can make you pull your hair out if you have any
This isn't just my experience. Over at the Bottlehead forum, the first thing the Doc blames when things come loose is a cold solder joint. |
