This is the full compliment of what came with my Opus Mia, minus the black set, that came mounted on the phones.I have tried to look at previous posts to try to see if it is posted but to no avail. In the case, is it meant to be missing 2 nozzles (meaning is there only 6 pair of nozzles including the one attached the IEM). Also, does it come with the mini IEM case like the RAH? (Did not find any for Semper) Just doing an inventory check for my sanity. Thanks.
IMR Audio : Sonic Adventures & Impressions
- Thread starter NellieG
If you are asking whether it's normal for the silver and grey nozzles to come without dedicated filters, then yes - I have three sets of IMR earphones and in none of them do the grey and silver nozzles come with filters.I have tried to look at previous posts to try to see if it is posted but to no avail. In the case, is it meant to be missing 2 nozzles (meaning is there only 6 pair of nozzles including the one attached the IEM). Also, does it come with the mini IEM case like the RAH? (Did not find any for Semper) Just doing an inventory check for my sanity. Thanks.
Aside from reference recordings, old rock & classics, who here enjoys a bit of filthy minimal? IMRs seem to love it. I for one like giving my OM's DD a massage once in a while and they seem to enjoy it cause they reward with an awesome sound & coherence.
Of course, you should get the flacs for best sonic results.
PsiCore
- Jan 21, 2007
Semper vs Rah, anybody?
I recall someone wanted to do a comparison, so just a reminder here
- Mar 1, 2009
Thank you all for being so helpful in the inventory verification for Semper - my Semper is still burning in, cannot compare with the RAH yet.
Good track to test the low end of the Semper is Lana Del Rey - high by the beach
I'm not a bass head but can appreciate great sub bass.
I am interested in the Mest and Volt, can anyone here do a comparison to Semper?
I would say Semper is better than Rah in every way, which is expected: better controlled clean bass, excellent mids et good highs with a better soundstage. Rah is excellent for vocals since it is mids centric. On the other hand Semper needs more power to shine. If you are planning to use your smartphone as a source, you better go with RahSemper vs Rah, anybody?
Really? I don't find the Semper to be that power hungry at all. On BTR5, balanced output, I'm playing it at volume 12-14. For comparison, Moodrop Blessing 2 needs volume at 14-16 (balanced) to be as loud. Not to mention TinHiFi P1, which needs 15-17 (also balanced). I haven't tried it single-ended, though. I'll have to switch the cable and try the Semper with my Aune S6 desktop dac/amp.On the other hand Semper needs more power to shine.
I said in comparison with RahReally? I don't find the Semper to be that power hungry at all. On BTR5, balanced output, I'm playing it at volume 12-14. For comparison, Moodrop Blessing 2 needs volume at 14-16 (balanced) to be as loud. Not to mention TinHiFi P1, which needs 15-17 (also balanced). I haven't tried it single-ended, though. I'll have to switch the cable and try the Semper with my Aune S6 desktop dac/amp.
runningwitit
- Aug 10, 2015
LolI said in comparison with Rah
Infoseeker
The Rah for chilling late night use is nice. Much softer sound for easing off slowly at night.
ChrisOc
We have almost reached the end of the stage one of our First Head-Fi Members' Poll. Stage one of the poll closes at Midnight GMT tomorrow.
Only the top 5 in each category will go forward to stage two. Get your vote in for your favourite IEMs and maybe they will get into the top 5.
https://www.head-fi.org/threads/the...r-monitors-2020-please-read-the-rules.950854/
NellieG
Its been a while that I have listened to this masterpiece of a set and shared it but inspired by your post I have to give the gift that keeps on giving.
Kundi
Never look back is an awesome song.
