I'm definitely in love with Semper. Very emotional IEM. Listening to Ella Fitzgerald on them makes me almost cry
IMR Audio : Sonic Adventures & Impressions
- Thread starter NellieG
runningwitit
- Aug 10, 2015
My Sempr is still burning. They will be at 96hrs tonight.
Gave a short listen last night, not impressed....
AlexCBSN
Filter combo?My Sempr is still burning. They will be at 96hrs tonight.
In addition to driver burn-in, you need to do some brain burn-in, too. If you come to the Semper from another unit, especially one which you know very well, the Semper (and by extension any other earphone or headphone) will sound off to you. Allow your hearing and brain to adapt to it. Start with the pink/pink nozzle/filter combo since it's pretty neutral.My Sempr is still burning. They will be at 96hrs tonight.
runningwitit
- Aug 10, 2015
I went from black/black ( to help the burn process) to purple/purple. The purple along with going from closed to open port, gave a more detailed presentation.Filter combo?
However, it's just crazy to me that he would make the 2 pin sockets so recessed that I can't use any of my good cables! The disappointment!
runningwitit
- Aug 10, 2015
Gotcha!!In addition to driver burn-in, you need to do some brain burn-in, too. If you come to the Semper from another unit, especially one which you know very well, the Semper (and by extension any other earphone or headphone) will sound off to you. Allow your hearing and brain to adapt to it. Start with the pink/pink nozzle/filter combo since it's pretty neutral.
- Mar 27, 2013
I love the overall SQ of Semper and it would be an exceptional product if the fitting is similar to OM- Listening session for me on Semper is not as prolong as its siblings.
Wearing Semper in an awkward manner at a protruding angle for the optimum SQ with the biggest soundstage at times tends to disrupt continuity in listening and enjoyment with readjustment is certainly not ideal to any music lovers.
Without the filter segment, it sits quite perfectly in my concha. But the SS is way too aggressive for my old ears. Bob may needs to case study and rework his shell for better fitting on his new implementation if there is one in the pipeline.
- Mar 27, 2013
You may need to use a small file to file the four coners of the 2 pin plug so that it is able to slot nicely into the slightly rounded socket.
runningwitit
- Aug 10, 2015
I hate surgery...You may need to use a small file to file the four coners of the 2 pin plug so that it is able to slot nicely into the slightly rounded socket.
Lol !!!
- Mar 27, 2013
I hate surgery...
Lol !!!
In this hobby we tends to do crazy stuff...Lol.
AlexCBSN
Yep...In this hobby we tends to do crazy stuff...Lol.
- Mar 27, 2013
Yep...
Base on my read, I bet you are one crazy guy whose drawers must be littered with Pebbles and Shells...hehehe
runningwitit
- Aug 10, 2015
Is it me or does the Semper sound like a bigger sounding Rah?
Now@96 hrs.
Now@96 hrs.
astr0n0m1nus
Over 350 hours on PB2 and I find that the sound has completely settled (since after around 300 hrs). Switched to EA Eros Hybrid II cable, purple bass filter with green upper filter, Azla Sedna Earfits and closed back - this is my final setting of choice after hours of listening and tons of tinkering going back and forth with various filters! I must say that the PB2s are exquisite sounding with any genre of music I throw at it. It has been a long journey with this particular pair of IMRs but patience has been rewarded...extremely satisfied. Thanks Bob!
Have you tried using short-stemmed and/or smaller than usual eartips for deeper insertion? I found that it helps a lot with the Semper's fit.I love the overall SQ of Semper and it would be an exceptional product if the fitting is similar to OM- Listening session for me on Semper is not as prolong as its siblings.
