Ryokan
I guess it is because of the BA drivers. Have you tried Acoustune 07 or Spiral dot eartips or Azla sendan Light(short) yet?
Got a few old spiral dots somewhere will try those, often got goo results with them. Stopped buying tips for a bit as spent way too much on different sizes and don't use Xelastics at all any more after getting Crystals, I find Xelastics dull the high end and quickly end up misshapen. A few have mentioned Azla Shorts might try some but they look very shallow fit so I'm dubious.
I've just started using some very wide bore tips possibly from Szalayi iem's, which bring great clarity, spacialness and not a hint of boominess I get from the standard ones that look like Symbio's.
Currently using TRI Clarion's, (after experimenting with foams which just take the edge off the highs, bass is deeper though) which give good coherent/balanced sound: clear, spacious (height and width) and satisfying bass - though not as deep/impactful using foam tips.
