holsen
L O LThat's the easy part, it begins with do and ends in it and then basically repeats on itself.
IMRs have so far fit me just fine, so Imagine these will be even better. I'm working on assembling the funds for one of new Semper Spots.
With shallow wide bore tips similar and including Tennmak Whirlwind, finally, Opus shell fits relatively easy, doesn't stick out too much, but with that choice of tips and bass reducing nozzles, isolation is below average and not NYC commute ready, even though I use closed rear port that I also seal with tape. Those nozzles have air holes in them so sealed back is moot. It's still good enough to use at work and away from busy streets outside.For all you lucky, fortunate and otherwise overjoyed Opus & New Aten Owners. Could you comment on shell size, fit and isolation with the closed port? @Aphex72 thanks for those pics. Would you mind snapping a side profile pic so I could get an idea of just how deep they are and to see how much the interchangeable port portrudes from the shell.
Thanks. I'm getting ready to make a decision on the next and last IEM for a while (yeah, right) But isolation and sleepability are important to me for the next one. Thanks!
Hi, what are the gold-looking IEMs in that pic?they are probably not the best choice to sleep in to be honest.
@Layman1 isnt rose gold but chrome gold and it’s difficult to photograph with smartphones...
I will retry with daylight
I'm using the stock cable and is sounding fantastic to me , just sayin'.Yes it's and sounds gorgeous with Penon OSG Cable, stock cable isnt quite good for this IEM
Is that the Opus Mia? They looked a rather bling-y yellow gold on the official website photos, but those IEMs in your pic look more like rose gold or something?
This bling bling set up delivers mind blowing SQ beyond the 200hrs burn in. Been grabbing attention these days, and now able to accept high gain on my MAX and up to speed with fast tracks rendering DT and Mike Portnoy “machine gun” like drumming (kick drum) deliciously in different flavour to PB1.
Loving it and reckon it will even get better.
