So that will be a continuous run and not limited one off?200 per year
IMR Audio : Sonic Adventures & Impressions
- Thread starter NellieG
NellieG
Yes as there are no more special builds anymore, everything is "In Stock"So that will be a continuous run and not limited one off?
Hello everybody. Is there any general discount for buyers? I would like to try them for the first time, and perhaps start with pre-owned. By the way, does anyone know what exactly the status means Pre Owned? Is this a buyer return?
NellieG
Hi, just drop Bob an email and open a conversation with him.Hello everybody. Is there any general discount for buyers? I would like to try them for the first time, and perhaps start with pre-owned. By the way, does anyone know what exactly the status means Pre Owned? Is this a buyer return?
Info@Imracoustics.com
RumbleWeed
It goes like thisHello everybody. Is there any general discount for buyers? I would like to try them for the first time, and perhaps start with pre-owned. By the way, does anyone know what exactly the status means Pre Owned? Is this a buyer return?
New=Brand New Item in perfect un-used Condition.
B-Stock=Item "Like-New" but with slight imperfections ie.Blemishes in Paint.ect..
Pre-Owned=Customer Return which has been fully checked and in perfect working order.
Hope this helps?
Yes, thanks everyone for the answers
behemothkat
Guys, was anywhere mentioned if DM/Avalon shells size/dimensions similar or the same as Halcyon or RAH shells?
Definitely looks deeper/thicker than Rah. Dont know if Halyon was bigger than Rah though.Guys, was anywhere mentioned if DM/Avalon shells size/dimensions similar or the same as Halcyon or RAH shells?
I cant imagine getting 2 BCs, 11mm DD and e-stats fitting into Rah shell.
While were at it. What is a general consensus regarding fit of the newer (Semper) vs the older Rah/Halcyon shells?
Which one you all found better fit in general?
monsieurfromag3
The Semper shell is heavy and extremely deep which subjects it to cable pull. I have to draw the cable cinch up to my chin to counter it (it’s dorky). The fit with the Halcyon and Rah was easier.Definitely looks deeper/thicker than Rah. Dont know if Halyon was bigger than Rah though.
The depth of the Dark Matter/Avalon shells concerns me to be fair, they are much thicker than the Elan/Ozar.
Edit: also the font on the earpieces… I don’t like it.
AlexCBSN
Halcyon was bigger than rah, mainly cause of the amplifiers
I asked Bob whether the Avalon was more closer in size to the Rah or Elan. He mentions that it is closer to the Elan. I'm quite happy with the Elan size and fit so will try the Avalon.Guys, was anywhere mentioned if DM/Avalon shells size/dimensions similar or the same as Halcyon or RAH shells?
The Rah actually fits me well, but sticks out more than I like it to.
behemothkat
Thanks, RAH also fits my ears well, so, you helped me to make my decisionI asked Bob whether the Avalon was more closer in size to the Rah or Elan. He mentions that it is closer to the Elan. I'm quite happy with the Elan size and fit so will try the Avalon.
Do you mean deep as in having deep insertion in the ear canal or deep as in wide to accommodate all the drivers inside?The Semper shell is heavy and extremely deep which subjects it to cable pull. I have to draw the cable cinch up to my chin to counter it (it’s dorky).
I think the first 50 were the orders that are coming with wonderous gifts
After Bob's email a few hours ago (about an additional 50 Avalon slots) I thought I would double check with him on whether Dark Matter also got the experimental tuning nozzles and goodies. His reply:
"The first 50 Avalon and 50 dark matter will get the experimental system, stickers, numbered card and message from me as well as some other goodies"
Now even happier I ordered both within the first 50 slots!
UnderTheHill
- Oct 10, 2016
I have no fit issues with any IMR products, I have R1 Zenith, Rah, PB One, Aten R2 Red, and Semper. Out of all of them, the Semper does stick out the most and is the heaviest.
