behemothkat
Probably Halcyon and RAH. Semper has a good fit without any tip - so, i selected the most 'smallest' to get perfect insert and fit: Radius Deep Mount EarpiecesDefinitely looks deeper/thicker than Rah. Dont know if Halyon was bigger than Rah though.
I cant imagine getting 2 BCs, 11mm DD and e-stats fitting into Rah shell.
While were at it. What is a general consensus regarding fit of the newer (Semper) vs the older Rah/Halcyon shells?
Which one you all found better fit in general?
