Ace o' Spades
- Jan 29, 2006
Well...I just looked up the price to make 2 of these boards. At $87, I might as well buy a new set of cans.
Originally Posted by jSatch These are two different things. Briefly, the P to S connector is a single, series, in-line resistor. This will attenuate volume (added resistance), and increase impedance. This change in impedance will change the sound sig, as seen in this thread to 'customize' the sound, and as used by Ety in their P to S connector. The 'Hissbuster' (a series, R2, and parallel, R1, resistor) will attenuate volume without a change in impedance. This will increase the load the amp sees so you won’t hear the background hiss anymore, but will not change the sound sig of your phones. These simple circuits, as in the Hissbuster, are utilized in crossovers (XO) in room speakers to equalize the output of the different speaker components (tweeter, mid, woofer) in a multi-speaker system without changing the sound sig of them. If you have a decent speaker system, check the XO to the tweeter. Chances are it will have this R1, R2 circuit along with a capacitor in series for a 1st order XO. The cap is a high-pass device that cuts off lower frequencies at approx 6 db per octave. 2nd order (12 db per octave) and on up XOs, for faster attenuation, get a tad more complicated, as will the addition of notch filters, etc if utilized within the XO. Clear? |
Originally Posted by Ace o' Spades EDIT: Dang it vYu, got your post in before this one. Did you read the entire post?: This is the schematic for a simpler (and therfore cleaner sounding) switchable HD-bass pod. The concept is extremely simple, but he challenge will be incorperating it into a pod of sorts that will look professional. If I decide to I can make one into an altoids tin just for fun, even though it will be a bunch of extra space for 4 resistors, a switch, and input/output jacks. Schematic: I am getting loads of ideas in my head right now for this project. Maybe if I decide to put it into an altoids case I will use the extra space for Chu Moy's Crossfeed circuit... |
Originally Posted by Ace o' Spades Well...I just looked up the price to make 2 of these boards. At $87, I might as well buy a new set of cans. |
Originally Posted by jSatch /img/forum/go_quote.gif Maybe 100-Ohms next? |
Originally Posted by Ace o' Spades /img/forum/go_quote.gif I finally got around to making a P-S adaptor for these with some leftover 47-ohm resistors from my original Podectomy project. This brings the impedence up to 100 ohms (or 99, but close enough). I seriously don't reccomend it. The bass almost dissapears, leaving a rather cold, lifeless sound even with a good amlifier backing them up. I'd say the best values for this mod (in ohms obviously) are 22ohms, 47ohms, and 68ohms from my own input and what has already been said. |
Originally Posted by scottiebabie /img/forum/go_quote.gif i did my pod mod about a mth ago. tried both 33ohm n 47ohm resistors. settled on the 33ohm juz coz it ran fine with the requiste volume juz off the headout of my ipod 5g. ampless, the depodded 33ohm iM716 sounded sweet and IMO, like a mini HD600. another satisfied pod mod iM716 owner here, thxs to jsatch thread |
