Originally Posted by lipidicman
Would adding impedance to my CX300 help the hiss with the shuffle, or should I build one of these:
http://www6.head-fi.org/forums/showt...ght=hissbuster
Adding impedance (the P to S) or dropping the voltage (the hissbuster) basically
These are two different things.
Briefly, the P to S connector is a single, series, in-line resistor. This will attenuate volume (added resistance), and increase impedance. This change in impedance will change the sound sig, as seen in this thread to 'customize' the sound, and as used by Ety in their P to S connector.
The 'Hissbuster' (a series, R2, and parallel, R1, resistor) will attenuate volume without a change in impedance. This will increase the load the amp sees so you won’t hear the background hiss anymore, but will not change the sound sig of your phones.
These simple circuits, as in the Hissbuster, are utilized in crossovers (XO) in room speakers to equalize the output of the different speaker components (tweeter, mid, woofer) in a multi-speaker system without changing the sound sig of them.
If you have a decent speaker system, check the XO to the tweeter. Chances are it will have this R1, R2 circuit along with a capacitor in series for a 1st order XO. The cap is a high-pass device that cuts off lower frequencies at approx 6 db per octave. 2nd order (12 db per octave) and on up XOs, for faster attenuation, get a tad more complicated, as will the addition of notch filters, etc if utilized within the XO.
Clear?
