Gino
- Apr 2, 2003
The triple flanges work for me too. I've been using them for over a year (has it been over year since these IEMs came out?).
After a quick rummage through my parts bin i decided to give it the 'royal' treatment. I used nice blue Dale RNC60 mil-spec 1-watt 1% tolerance metal-film resistors. 52.3 ohm, because that's the only size i have them in. And because i appear to be fresh out of 47 ohm resistors. But hey, these resistors cost like 83 cents each, and i could buy a dozen regular old 47 ohm metal film resistors for that much money. Never mind the logic. They sound good, and they look good. The difference vs. 47 ohm is small, but in the direction of slightly more bass. Making the connection between the ground leads is a chunk of 20awg silver-plated copper, to color-coordinate with the blue resistors, of course. The sound is certainly more clear without the pod. Bass is present and accurate without being exagerated or fuzzy like the bass setting on the pod made it. |
Originally Posted by facelvega /img/forum/go_quote.gif Just showing off my new sharp new podectomy, which I've just now seen only in this pic from modder extraordinaire ericj. Here is the man's report: ![]() |
Originally Posted by DoomzDayz /img/forum/go_quote.gif interesting, 52 ohms sound be less bass and more air. |
Originally Posted by Gino /img/forum/go_quote.gif If I were to go amped, I'd go in the direction of the ER4S experimenting with 68 ohms and higher. |
Originally Posted by Andrew_WOT /img/forum/go_quote.gif Actually 68 Ohms works just fine from unamped Zune and there is plenty of bass. |
Originally Posted by facelvega /img/forum/go_quote.gif But do I remember correctly that you were strongly in favor of the HD setting over the bass one? How does 68 Ohms sound compared to them, to your ear? |
Originally Posted by Andrew_WOT /img/forum/go_quote.gif Yes, I was, although I cannot recall sharing that on this board. ![]() |
