You need to stop replying to what you think people are saying and read and understand what they are.
Originally Posted by SmellyGas /img/forum/go_quote.gif
There are a handful of people who upgraded their amps and the treble problem went away. This could have been due to additional breakin over time, not your amps.
I still get irritating sibilance if I plug them into my old amp. It's not irritating with my new one. The combination of the HD-800s and my new amp was a plan from the beginning, which I should have made clear. I didn't buy a new amp after buying the HD-800s as I predicted, correctly as it turned out, that an upgrade would be necessary to get the best results from them.
If not, what right do you have to demand that I upgrade my amp rather than return my phones? |
Maybe if you read my post again, you'd see where I also said,
"However, it is both true that better gear or different headphones are equally a solution."
No, sir, the flack is coming exclusively (or maybe 90%+) from people who dropped $1400 on their HD800's, another $1000+ an amps, and are personally offended when somebody doesn't validate their purchase. |
I guess you missed where I said,
"If it wasn't already clear, in my case I don't like my HD-800s with anything other than my best amp and DAC and I'd say for many people and types of music they are a poor choice."
If you're so confident that your HD800's are the best ever, then why are you being so defensive? Why does it matter to you and the rest of the fanboy brigade what I personally think? |
Uhh, I didn't say that. Nor am I defending, I am saying that your lack of experience means your mind is closed to possibilities beyond your beliefs. What's not obvious to you is that what I'm trying to say isn't about the headphones themselves (I'd say it if you were ranting on about any other headphone I've listened with under similar circumstances) but about your lack of experience causing you to be too quick to judge. What you should be saying is that HD-800s don't sound good to you
with your rig.
Yes, the HD-800s sound like crap through low-end gear. So do K701s and Grados, in my experience. Good headphones can't magically make low-end gear sound amazing.
That you don't want to believe in the possibility of different sources and amps resulting in a radically different sound with headphones (or speakers for that matter) is your problem. You are the one missing out. Enjoy your expensive lessons.
