- Mar 20, 2013
Thanks, I'll do some tests.
Please share with us your findings, thanks
Stay updated on iFi audio at their sponsor profile on Head-Fi.
As to the DAC issues specifically, I don't have any info on that for you right off hand. In regards to the turning off that is not normal, and could be PS related, you can check this by using another PS rated from 9-15v no more, and see if that changes anything.Hello Friends,
I’m just facing some issues with iFi ZS connected to Technics SU-G700 with built-in DAC using USB. I already gone through the HW reset described on top of this thread but nothing changed.
Issue #1: Once I try to set up DSD Direct, it jumps back to DoP when saving the config (Technics supports native DSD stream!). I thought it should be a handshake issue between the ZS and the Technics DAC so I tried the same with iFi Go Link mobile DAC (same brand, no problem with communication, I thought). Unluckily the symptom is the same. Do you have any idea, what should be behind, and how can I solve it?
Issue #2. Hardver volume setting doesn’t work with Technics DAC. Considering that it works with iFi Go DAC (checked as well), I think it’s a kind of compatibility issue again. Isn’t it?
Issue #3: The ZS randomly switches off. It does this rarely, but it isn’t normal. Could the reason be the original power supply behind, came with the ZS? Will it be eliminated when using a quality linear power supply?
Thanks in advance for any advice!
Gabor
Hello,Hello Friends,
Gabor
thanks, I will pay attention on thisHello,
i also have problem with switching off, original power supply is ridiculous but that is not a problem.
At my house problem is with switching on and off lights in other room or hall, pay attention to it.
ZS is very sensitive on everything, like driving an alfa romeo you'll get to know problems you didn't even know could exist.
Thanks for the compliments, we do try to help here as much as possible. There is also another thread here on the Zen started by iFi in case you should need to post these questions there as well, here's the link...Hello!
I have reviewed this entire thread looking to solve a Mac-mini M-1/Tidal Connect/IFI Zen stream issue which is minor but annoying. I have received a simple work around for it from Tidal and Apple.
While reviewing this thread I was taken by members thoughtfulness and efforts to assist. As a result I thought I would to try the USB-A input for a NAS.
I have reviewed the introduction information and have several questions.
(Normally I would blunder through but as one error can result in complete frustration I thought I would ask the experts first.)
(Keep in mind I will not know what auto fills.)
NAS registration page before Scan is where I need help and where questions arise from.
1. Alias-I get it
2. IP Address of Network-Is this the IP address of computer or IP address of Router, or will this auto fill?
3. Path-“Music” listed-is this OK to use?
4. File Share Type-CIPS. (Or other?)
5. If CIPS-do I put user name from thumb drive or SSD?
6. If CIPS-do I put in password for thumb drive or SSD?
7. If no user name or password can I leave blank? Or do I need to put in Admin and leave password blank as in template.
8. Do I need to leave ON the DNLA function on App?
Broadly
9. Does Zen stream reload this data each time turned off and on?
10. Does anyone know the storage space on Zen stream off hand. I saw it once but could not relocate it?
I have only a .2 of terabytes so I should be OK
Many thanks in advance for any input!
S
The first step I would take would be a "soft" factory reset from the settings menu in the app, same page as checking for updates. Then update to the current firmware, see if the issues reoccur.@Mr BubbaHyde
After over a year of perfect operation, I’m having some odd ZenStream behavior.
At times the unit freezes, after being on for awhile. It disappears from the network. And even though still powered, it cannot be turned off by the power button. I have to disconnect the power supply. Once restarted it works ok.
Last night after a listening session I turned off my Marantz SACD 30n, which is the DAC connected to the ZenStream, and the ZenStream shut off as well on its own, something that has never happened before. Normally I have to physically power off the ZS.
Are these power related oddities software related and might be helped by a factory reset? Or is it some sort of hardware issue?
I’m using a 12V Farad Super3.
Thanks
I would still put in a support ticket or get one started just to see if maybe they have some reported issues like this as well.
The last thing I would try is swapping power supplies, even though you are using a very good one, just to eliminate possibilities.
Let us know how you make out after the reset! No need for the first post "hard" reset yet, at least in my opinion.
Cheers!!
Where do I submit a ticket? Outside of this forum, I have been largely unsuccessful at contacting iFi directly in the past.
