GuyM
Thanks a lot for the info M usicguy.12 volt booster. Mostly because I have other devices that use 12 volt. I don't own many 15 volt. So I wanted to be able to move the SBooster around if needed.
Plus I had one already so. I knew I like the 12 volt sound. When in dedicated modes with the 5 position dial you loose the IFI app access.
I made a post if anyone heard a sound difference between dedicated or AIO setting. Still waiting for a sound comparison.
m iscguy
Therefore, I will stop searching and will return to the AIO setting (position 1) once in a while to check updates.
On my side, I did not make an exhaustive sound comparaison yet but at first glance, the difference between 1 and 3 seems minimal... if any. Perhaps it is because I put 'off' all non-Tidal toggles in the app...and if it is, perhaps we can leave it in AIO setting to have access to the IFI app. À suivre...
Regarding the SBooster, did you try all three settings (12V-13V & 13.5V) and if you did, does it sound better with the higher voltage (13.5V)?
