Anyone have thoughts on sound comparisons to other DAPs?
iFi micro iDSD Black-Label - In-Depth Review
- Thread starter earfonia
The BL sounds a bit congested compared to the H2 listening via a Linn speaker system.
jmills8
Previously known as bmiamihk, jmills2
By "congested" you mean more bass, more analog ?The BL sounds a bit congested compared to the H2 listening via a Linn speaker system.
It sounded veiled or held back...I didn't really notice it until I switched back and forth with the H2. To be honest with you, it's not bad, per se; it's just what I heard. Of course the H2 is over 3x the price of the BL...
jmills8
You only using both as a dac and not using both as a dac/amp ? I think the hugo2 is a great as a dac but the ifi bl is better as a dac/amp.It sounded veiled or held back...I didn't really notice it until I switched back and forth with the H2. To be honest with you, it's not bad, per se; it's just what I heard. Of course the H2 is over 3x the price of the BL...
Good point as I was using both as a DAC being fed digitally by an SP1000.
Promenadeplatz
Battery life and charging time.
I didn’t have enough time to do an extensive observation of the battery life. Managed only to do a single continuous playback of Pink Noise at 250 mV at 16 ohms, at Normal power setting, and the battery last to almost 8 hours. This is pretty much like driving headphone continuously at Normal power mode. At Eco power mode the battery is expected to last longer.
Below is the charging curve of iFi micro iDSD Black-Label from battery level at empty state to 100%. It requires around 6:16’ hours to fully charge the battery.
According to specs battery capacity is only 4800mAh and this measurement shows a capacity of well above 6000mAh .... how does it come? Great great great review btw ... thanks a lot!!!
- Mar 20, 2013
If your ears are telling you this, that's perfectly fine.
It is indeed.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
The BL is a great piece of gear and I've been using it as an amp fed from an LG G7 to Audeze's i4 - it's a great transportable setup for me.If your ears are telling you this, that's perfectly fine.
It is indeed.
- Mar 20, 2013
Thanks for good words. Well, we're *very* pleased how micro iDSD BL turned out. We really are. Enjoy!
there is popping sound (dub) when turning the micro BL ON, is this normal ? if not, how to fix it ?
it the same thing for both my headphones or my speakers connecting to my RCA out
- Mar 20, 2013
A fiarly small one is normal, yes. Please take a look here:
http://support.ifi-audio.com/kb/faq.php?id=378
fungus amongus
- Dec 14, 2008
![IMG_20181223_184835.jpg IMG_20181223_184835.jpg](https://cdn.head-fi.org/a/10215954.jpg)
Rayzilla
Just PM the ifi Audio member on here and he'll take care of you. Service like only a very few can hold up to.Do you guys know where can I get an iEMatch button/switch? Lost mine.
- Mar 20, 2013
Please open a support ticket here: https://support.ifi-audio.com/
..and we'll try to help you!
