fungus amongus
- Dec 14, 2008
Thanks man!Just PM the ifi Audio member on here and he'll take care of you. Service like only a very few can hold up to.
Sure! Thank you as well.
I've read that the battery can be bypassed by first plugging the device into a computer and then turning it on, preserving its cycles when used as a desktop dac/amp. Does the battery still get charged constantly though and doesn't that ruin it over time?
How hot does it get with other settings? Does it matter how many ohm's the headphones have?
My current headphones are 40 ohm's, but I will switch to a pair with 300 later.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Thanks for the reply, but that's not what worries me.Well, sensitivity of headphones determines how difficult they are to drive. iDSD BL can get warm but won't toast anyone's hands or pockets
I have a condition called MCS (Multiple Chemical Sensitivity). It makes me react to all kinds of things, including the chemical vapors that gets emitted when electronics heat up. It never seems to disappear.
I have a 5 year old computer and it still does it. My phone is a tad bit better, allowing me to spend a few minutes at a time, without any reaction.
However I don't react at all to a couple of Bluetooth receivers that I have (they never gets hot). If I stay 2 meters or more from my phone, then I am safe (the same room as a computer, isn't safe enough).
If the unit stay close to ambient room temperature, then it might be okay, but reading the review, it seems like it will be higher than that...
Thanks again. I might, if someone can provide me with some figures.What we suggest at this point is to contact your local iFi representative and try the product for yourself. Our return policy is generous, hence if iDSD BL doesn't do the job for you, you'll be refunded.
Thank you! Happy Holidays!micro iDSD BL use USB power only in ECO mode, whereas in normal/turbo modes both USB line and battery are in use. And yes, battery in USB mode is charged.
Hey guys and happy holidays.
I recently started using my iDSD BL with Tidal HiFi (MQA). I've notice there is a setting (in the desktop app) to Passthrough MQA (Disable software decoding of MQA). Should I enable it or should I left it turned off?
Second question: how can I stream MQA through tidal app to iDSD?
Please watch this short vid we did a while ago and that's it:
Thanks. I've unchecked MQA Passthrought, though Micro does not have magenta LED, am I right?
and for the second question. Can I stream MQA from my android phone (Galaxy S6) to Micro ?
I want to plug my phone to this while using both the DAC and amp sections, i purchased 5 female to female connectors so that i can plug my phone cable directly, but all the 5 connectors (from different brands) did not work, unfortunately i don't have other devices which have the ODD male connector to test my connectors, so what's the problem exactly ?
