Vitaly2017
I am wondering if something like an idefender3.0 or isilencer3.0 would help here? maybe its my lg type c usb has dirty signal output ???
I have both and I can tell you the Ifi Micro doesn't have the smoothness of the PHA-3. Yes the Ifi Micro can do more while costing a lot less but there something special about the PHA-3. As a headphone DAC/AMP the PHA-3 kick the Ifi to the curve, because the PHA-3 I mostly use the Ifi Micro in my 2 channel system as a DAC.Has anyone tried both the Sony PHA-3 and IFI Micro with iPod classic? I know that you can only use Micro with iPod classic through the line out connection but I'm still interested to hear how it compares in SQ to PHA-3 with the balanced mode. I know the Micro is better than the PHA-3 pretty much in every category but I would be mostly using it with my cd-player and iPod Classic and only occasionally as a desktop amp (only when I'm travelling etc.) I already own a PHA-3 and was wondering if getting the Micro would make any sense for my use (I mainly listen to music with Hifiman HE-560).
I have had the same issue actually.I've had a little issue with my iDSD Micro BL. I left the device turned on mistakenly for some few days up till the battery fully drained off. I was hard put to reawaken it. When I turned the iDSD on, plugged into my PC, the light would start flickering, alternating green and red light. Then when I tried to play music back with the iDSD on USB mode on the PC, the playback would stop and the light turn off after a few minutes; the system would not recognize the IDSD as if it would have been unplugged. It seems the iDSD can't work when the battery is drained off even on USB mode, which is strange. Now I having it getting a full recharge. Any comments?
I surprised no one has responded. Try plugging into your PC "before" turn the iDSD on to operate as bus power mode.I've had a little issue with my iDSD Micro BL. I left the device turned on mistakenly for some few days up till the battery fully drained off. I was hard put to reawaken it. When I turned the iDSD on, plugged into my PC, the light would start flickering, alternating green and red light. Then when I tried to play music back with the iDSD on USB mode on the PC, the playback would stop and the light turn off after a few minutes; the system would not recognize the IDSD as if it would have been unplugged. It seems the iDSD can't work when the battery is drained off even on USB mode, which is strange. Now I having it getting a full recharge. Any comments?
Probably a good idea to give it some charge first before trying to play anything. There are some variables at play that might affect whether or not you'll be able to play anything at lower battery levels. For example, using eco power mode will leave you with additional power from the USB connection to charge the iDSD. However, if you're using Normal/Turbo, you'll drain the battery even if plugged in via USB.I've had a little issue with my iDSD Micro BL. I left the device turned on mistakenly for some few days up till the battery fully drained off. I was hard put to reawaken it. When I turned the iDSD on, plugged into my PC, the light would start flickering, alternating green and red light. Then when I tried to play music back with the iDSD on USB mode on the PC, the playback would stop and the light turn off after a few minutes; the system would not recognize the IDSD as if it would have been unplugged. It seems the iDSD can't work when the battery is drained off even on USB mode, which is strange. Now I having it getting a full recharge. Any comments?
Have you had any luck getting to work again in the last few days?
In that case, I think you'll be fine! I leave my BL on all day at work in Eco mode and then use it on the commute home and casually on the weekend. I've never had to dedicate any time to charging it since I got it a few months back. Given you're using Turbo mode, it makes sense that without some charge reserve it wouldn't be able to operate as Turbo will draw more than it receives from USB power.I agree what you say. I was using it in Turbo. I've had no time to test it since the iDSD charging takes so long and personal issues have kept me away from my PC. When the charging finishes I'll try it and tell you.
Turbo is great if you want to push bass so low it's not even audible. When I listen to No Love by Death Grips on Normal I can hear very noticeable distortion in the bass. On Turbo my entire skull is shaking (and distortion is gone)In that case, I think you'll be fine! I leave my BL on all day at work in Eco mode and then use it on the commute home and casually on the weekend. I've never had to dedicate any time to charging it since I got it a few months back. Given you're using Turbo mode, it makes sense that without some charge reserve it wouldn't be able to operate as Turbo will draw more than it receives from USB power.
On another note, unless you're driving a HE6 -- or the like -- I can't imagine what would need Turbo. I found that I barely needed Normal mode to drive my HE560's and have almost no volume control if I use Normal with my Aeons (though they do sound fuller in normal). No idea what you're gear is of course, but man... I struggle to think of when I would ever use Turbo.
