Also, maybe unrelated but sometimes I'm losing a split second of the beginning of the first songs in the playlist. Does it happen to anyone?
This means your iDSD has entered sleep mode. It takes half a second to wake up.
Mine have this feature/problem as well, its not sleep mode, I loose half a second of playback happens after just 10 seconds of no data on the USB. Got some lame answer from ifi that i could just run a program in the background that would output empty audio constantly. There is not indication on the device or any of the programs that it is in some kind of USB off mode.
this has happened with all the firmwares i have tried so far, and both on PC and Phone
> Computer Management > Device Manager > Universal Serial Bus Controllers > Generic USB Hub
You will have several Generic USB Hubs and you need to find the one that your DAC is attached to or you could do all of them.
> Generic USB Hub > Right-Click > Properties > Power Management > Untick the relevant box
Is MusicDirect.com a reasonable place to purchase from?
I never tried them, but have you tried
http://www.ttvjaudio.com/SearchResults.asp?Search=Idsd
So, unfortunately they didn't respond to my email.
