gr8soundz
- Jun 28, 2014
@ ifi audio.... . when do you plan on shipping out the ipurifier 2 with the correct USB connector for the idsd micro.... like to get one please...
thanks
+1
thanks
I've just tried the 5.1B based on your findings, but unfortunately the pop noise on DSD wasn't resolved for me. It behaved the same way as 5.10.
This is with micro iDSD on Windows 10 with the latest JRiver, playing DSF DSD64 files.
I found that ASIO with DoP disabled has the least amount of pop noise, but still quite noticeable compared to 5.0. Going back to 5.0 fixes the pop noise completely regardless of ASIO or DoP.
Hope there is a good fix for this, because some people reported the 5.10 sounds better, but I can't use it because it gives the speakers a big pop.
It sounds different, there seems to be more 'texture/detail' notably in middle-upper part of sound. With my 'desktop' usage Micro iDSD -Lake People headamp -Sennheiser HD800 hp, there is no direct need for this.
Interestingly, with my setup, firmware 5.0 seems to have more 'black/empty' background behind each sound/note and each sound starting point seems to be more clear. Vers. 5.0 seems to to be little more on cooler' side and 'relaxed'.
With very good recordings it is possible to say, that at least acoustical instruments have little (but perceivable) different 'timbre/sound' with firmware 5.0 or 5.1...
I don't know which version is more correct/true to original recordings... With highly detailed/analytical HD800 I prefer 'cooler' version of firmware
Anyone know where to get a right angle rca coax to coax. So this Micro to DX90
Hmm... I guess I will have to compare the 5.0 and 5.1 quite seriously. I'm always a bit skeptical about the firmware update affecting the sounds (especially on DAPs, a lot of people go over the top about it), but Knowing iFi does a lot of good in-house R&D, it sounds plausible.
I am finding with both my Nano and Micro iDSD's that the new FW has increased the texture, it appears to be most noticeable for me on brass instruments and bass notes. I appreciate I might be suffering from expectation bias, but there does seem to be a change in granularity. I am currently listening to Kirsty MacColl's 'Desperate Character' and it sounds fantastic!
Thank you iFi.
Wait am I being an idiot here? Can you not use IEM's in that one or do you have to use them in the 1/4 side with an adapter?isn't the 3,5mm port an input?
