Triodemode
- Sep 5, 2014
It was my understanding (thus far) that, if a file can't be upsampled on the fly (like 48/96/192khz in foobar) or to get dsd playback via pcm on some devices, then another file format (container) like DoP is needed. I believe the DoP container is like pre-converting the file which can then be played back "natively" on the device while the Micro picks up the dsd info.
To my knowledge, the iDSD Micro doesn't write anything to the hard drive when upsampling lower res files.
I may try converting a few files to DoP and see how it works.
This is correct... DoP just wraps DSD in PCM markers during real time playback for use by DACs that cannot handle DSD directly, or in the micro's case the ability to handle 96 and 192khz resolutions. I thought you were speaking previously about DoP as another format stored on your hard drive. We are on the same page here.
As an aside, my old windows XP duo core (2008 vintage) only hits 60% CPU with no stuttering while playing PCM over DSD512 with the micro! I'm convinced that a clean and efficient OS is more important than sheer processing power at these DSD rates. Windows 7 & 8 are just much more bloated resource hungry versions of XP IMO.
