dan.gheorghe
- Mar 15, 2010
Here is my review of iFi Micro iDSD.
"One of the strong things about this unit is that it sounds quite natural for a Delta Sigma."
Actually the DAC is a hybrid. The top 6 bits are pure multi-bit.
The treble is better from the RCA outs. If you connect it to a micro iCAN for example, you will hear a bit more going on up top. The headphone amp in the micro iDSD is a class A/B type in order to keep the heat and power consumption low. It's good but it doesn't match a good class A design like the micro iCAN.
I personally find the bass boost to add little or no mid-bass at all and to add sub-bass. I listen to a lot of rock and hip hop.
Thank you, techno. I didn't find that info about the DAC chip anywhere. Where did you read this?
http://www.head-fi.org/t/711217/idsd-micro-crowd-designed-cutting-edge-portable-hi-res-on-ios-update-page-134/60#post_10404689
Thank you very much. Added the info in the review. This seems like a very important feature in my opinion. They should also write that on their website.
On page 1 of that thread, there is an index of important posts.
Hi! i've been combing these threads to find what amps some of you guys pair the Micro iDSD with. Could some of you please kindly share your iFi Micro iDSD set ups with full desktop amps / tube amps please? thank you!
A bit perfect mode question to the folks here. I understand this mode only applies a filter with no oversampling and when playing 16/44.1khz red book music there will be a higher noise floor however, I am clearly hearing digital noise during quiet passages or when the music is paused (of course at 88.2khz or above the noise is gone).
Is it possible my unit's filter may be out of spec and allowing this noise to be louder? Just trying to gauge whether the noise from my iDSD micro is at a higher level than what others are experiencing. If this noise is heard by other users during quiet musical passages as well, then I understand this is just a tradeoff for what many consider (myself included) to be a more analog sound.![]()
