iFi Hip-DAC Impressions Thread
Apr 17, 2021 at 6:48 PM Post #436 of 768
My connection path: iPhone 12-Camera Connector-hip dac-headphones. I'm not noticing any pauses using this setup. Maybe I'm not attentive enough, who knows?
If there were any pauses, I reckon you'd easily hear them :L3000:
Apr 19, 2021 at 8:39 PM Post #437 of 768
Just curious: Why do you need blue USB cable when using hip dac and Apple Camera Connector? One of the cool things about the hip dac design is that the Camera Connector snaps right into the hip dac, eliminating the need for an adapter or second cable.
I like to use my phone while listening to music and the Apple camera connect kit adapter was too short so I used the extension cable.
I returned the Hip Dac and now have a Zen Dac connected to a laptop. Using Spotify connect to control it from my phone.
I was also having a problem with the 4.4mm connector where the left channel would not work unless I pulled the connector out slightly. Figured it was best to return it and get something that would be better for couch potato use...
Apr 20, 2021 at 3:40 PM Post #438 of 768
How do you find ZEN DAC after hip-dac? There's a reason why I'm asking, but I'll wait for your reply first :)
Apr 22, 2021 at 5:20 AM Post #440 of 768
I like it. Not quite as much of the jackhammer punch in the bass but just a bit more refined.
ZEN DAC was designed as a desktop version of hip-dac. Having this in mind, have you found them alike in general?
Apr 22, 2021 at 1:21 PM Post #441 of 768
Yes, although its hard to compare since I don’t have the hip dac anymore.
Keep in mind that before I was just using the lightning adapter and small Bluetooth amps.
There’s a whole new dimension of detail down in the bass region that I just wasn’t hearing before. I’ve also found that Iems that I hated before sound much better. Moondrop Starfield for example sounded dull and lifeless on the Apple adapter but on these amps I actually enjoy them.
Apr 24, 2021 at 6:37 PM Post #442 of 768
Has anyone found a right angle cable that works with the Hip-Dac so i can stack my DAP with it? I tried the Xduoo one but the USB A side is too big for the hip-dac's cutout.
Apr 25, 2021 at 4:25 PM Post #443 of 768
Thanks a lot for your feedback and enjoy! :beerchug:
Apr 26, 2021 at 12:59 AM Post #444 of 768
The ones with sleeve from ifi wouldn´t fit?
@all:
How do you charge your hip-dac?
I found this in the manual:
Charging via USB-C
BC V1.2 compliant up to 1000mA
Charging via Samsung Galaxy A5 OEM Adapter won´t work for me. I charged on PC in the past.
Is the 18W Google Pixel 4a to powerful or not necessary to think about?
Thank you
Apr 26, 2021 at 1:50 AM Post #445 of 768
@all:
Charging via USB-C
Thank you
Which one are you referring to?
Apr 26, 2021 at 1:53 AM Post #446 of 768
Apr 26, 2021 at 2:15 AM Post #447 of 768
This one. Also available with other connector.
Yeah I'm more looking for a right angle one cause that one doesn't really bend that nicely with a dap stacked on top of the hip-dac
Apr 26, 2021 at 4:09 AM Post #448 of 768
Oh, then i overread it. Then just have a look on Amazon, FiiO or maybe ask Matt from ForzaAudioWorks for a custom cable.
Apr 26, 2021 at 7:47 AM Post #449 of 768
Apr 27, 2021 at 5:58 AM Post #450 of 768
Or maybe you could buy the ifi OTG and go for a L-Shaped Adapter for a reasonable price. But like i wrote, maybe a custom cable can be the way to go.
If your PC/laptop's USB port outputs 5V/1A, a regular USB cable with a USB-C plug on one end is all you need.
I used a regular USB Adaper from a Samsung Galaxy A5 and it doesn´t seem to charge. Result: permantly red blinking LED.
As i would like to save the battery for a long time, i asked for other options. So, i used the adapter of a Google Pixel 4a, charged in the manual mentioned three hrs.
His stuff is great!
Absolutly! :wink:
