rlw6534
Hello, I am on wifi 5ghz, with a nominal 1Gbps speed and an actual of about 300Mbps. Even high res music does not place much demand in terms of bandwidth so you should be fine with just more than 50 Mbps. If you stream locally rather than from the internet, is your issue gone?
I totally agree about bandwidth not normally being an issue. In fact, 2.4 GHz wifi might be preferable because of the significantly longer range, especially if you are moving around with DAPs or have walls blocking the signal.
