FooFighter
No!thanks, i will try...i should set this in the router, right?
Find an ip adress in the range of your subnet but outside of the DHCP range (so it's not assigned to another device by the router and configure that adress in the Zen Stream app.
So e.g your subnet is 193.169.1 and DHCP range is e.g
193.169.1.10 - 193.169.1.100
You can then e.g assign 193.169.1.101 as the static ip for Zen Stream
