srkbear
I swear I experienced the exact same problem several times before the firmware update. I had to factory reset my ZS several times, always after I accidentally disconnected my DAC from the ZS when it was running.Yes it did. All was perfect before firmware update 2.31.7. Thank you for your support.
With the latest firmware, the DSD settings can be modified in Roon in the software audio setup, with the ZS on “Roon Exclusive” mode, and that solved the problem for me. Fortunately at DSD 64 the performance of DOP should be equivalent to native DSD, but with a DAC like yours you should be able to achieve all the way up to 256. Let’s see what @iFi audio says. Best of luck…
