I cannot get Native DSD working. Whenever I select Native DSD, it reverts to DoP when I click save. My Copland CSA 100 Amp should be able to receive Native DSD. I also see a white light whenever I play a DSD file, the same colour as for a high-res FLAC. I beleive DSD should have its own colour?
Is this a problem and should I be able to fix it? Or is Native DSD and DoP basically the same?
I had this same problem countless times before I upgraded to the latest firmware. I had to factory reset the device to get it to stop. It always occurred when I disconnected my DAC when the ZS was on and running.
But since I upgraded to 2.31.7 (and now 2.31.8), I now change the native DSD setting through the Roon setup menu that opens in a browser window when you have the ZS in “Roon only” mode, and click on “device settings”.
I recommend that you do the following first:
1. perform a factory reset, connect your DAC to the ZS via USB and make sure both are on (and that your DAC is set to USB)
2. reconnect the ZS to your Wi-Fi or Ethernet, either through the iFi.local GUI or with the ZS app
3. Change to full settings in the “system” menu
4. Go to iFi.local/dev, enable beta updates
5. Go back to iFi GUI, turn off Wi-Fi hotspot radio in “network” settings. If you use Ethernet, turn off the Wi-Fi radio as well.
6. Go to “system” settings, check for updates and install 2.31.8
7. Go to “sources” menu and turn off the connects you don’t use (Spotify, NAA, etc)
8. Go to “playback options” and select your DAC (instead of S/PDIF), set DSD to native, and DSD volume to max
It should work now. If you use Roon, reply back and I’ll give you instructions on how to set the DSD settings through the software. To prevent this from happening again, always shut down the ZS before disconnecting your DAC.
