Looks like that the update is here...
This is very true. Since the Roon Ready upgrade, Roon only works for the ZS with S/PDIF connections. I previously detailed the other persisting bugs earlier in this thread. But none of them affect performance when on AIO mode.SPDIF works juts fine but need to discover where is my usb signal to my DAC)...it was lost somewhere. Mode 2.
but it is available in mode 1
and it turns back to SPDIF only when you switch it to mode 2.
So there is no USB signal in mode 2. It exists in mode 1 only.
It looks like the same issue was in beta version.
It’s a beta. The latest production release is 2.30.7, this is 2.31.7.Is this a beta release or a production release?
Production releaseInteresting, this must have been added recently—when I installed it over 2.31.6, all it said was fixed some Roon runtime issues. I’m pretty sure this is still a beta though—it was when I installed it. I’d have to revert to factory and reinstall to find out—I’ll try this evening.
Yes you are correct—I just reinstalled factory settings and performed a system update again, and the version 2.31.7, which was previously a beta release, has been upgraded to the latest stable version. Not sure why they kept the same version number, or why they didn’t fix the known errors still persisting first, but it appears that they did!Production release
Production releaseIs this a beta release or a production release?
