@Sebastien Chiu and
@iFi audio, I saw that you released another update today (2.31.7 beta) that purports to fix Roon runtime issues. I installed it, and am still noting the following issues:
1. Roon exclusive mode still defaults to S/PDIF only.
2. DSD audio settings in Roon still show 512 as an option, along with an option called “ERROR”.
3. Options for multichannel (5.1 and 7.1) are also persisting since the 2.31.6 beta, which obviously the ZS does not support.
4. Evidence of the bridge in vestigial form still remains in the signal path—when I identify my ZS as my endpoint, the ZS shows up twice in the path—presumably once as a bridge and again as an endpoint. When I leave my Topping DAC unidentified, the path only shows the ZS once—which is the setting I prefer because it seems to be working fine.
Other than these issues, when running in AIO mode everything seems to be working, if I select the correct parameters.
One other thing—every time I update firmwares, the ZS defaults back to S/PDIF and resets several fields in the ZS GUI, such as “favorites”, “Last 100” to disabled.
Thanks for continuing to work on this, I’m confident you’ll get it sorted out!
