I could not get my Tidal Connect client app using ZS 2.3.7 firmware to connect consistently using Ethernet connection for ZS, with Tidal Connect running on Wi-Fi (to same Internet/Wi-Fi router as my ZS is connected to via ethernet). But when I did a reset back to the firmware that shipped with my ZS, it works fine for me (Tidal Connect). But 2.3.7 adds support for MQA passthrough, which I no longer have since I went back to firmware that shipped the unit. When I hit the reset button, I am not sure which release level I went back to.
Here is a description of the fixes in 2.3.7 that shows up when checking for updates in the Settings of the ZS app:
Added MQA passthrough option to Tidal Connect, fixed Spotify Connect not compatible with some DACs, fixed DoP LED color, fixed infinite loop in config wizard, fixed progress bar not working.
2.30.6 -- Fixed light color when playing DoP.
2.30.5 -- Fixed no sound coming out of Spotify Connect with some USB DACs, added hardware volume control to Spotify Connect, added DSD/DoP auto select when switching output.
2.30.4 -- Fixed no sound coming out of Spotify Connect with some USB DACs, added DSD/DoP auto select when switching output.
2.30.3 -- Fixed infinite loop in wizard, added virtual USB DAC entity, enabled logfile upload to cloud.
2.30.2 -- Enabled debug mode switch and logfile generation.
2.30.1 -- Added MQA device auto detection to Tidal Connect, enabling 'Passthrough MQA' setting from UI.
2.29.9 -- Synced with bug-fixed Tidal Connect service(fixing occasionally stops playing), fixed auto detect USB DAC.
2.29.8 -- Suppress Tidal Connect audible noise out of SPDIF, fixed incorrect mdns device name, optimised system update.
2.29.7 -- Suppress Tidal Connect audible noise out of SPDIF, fixed incorrect mdns device name, optimised system update.
2.29.6 -- Optimised UI, updated some translation.
2.29.5 -- Fixed spdif DoP output, fixed error info from Foobar UPnP, optimised UI.
2.29.4 -- Updated pushwifi API, fixed some mixer bugs.
2.29.3 -- Enabled all channels of 5G.
2.29.2 -- Added speed info in system update, optimised OTA update, fixed wifi ESSID not supporting utf-8, hided some unnecessary hotspot configurations, fixed not showing wired IP, revised push wifi API, optimised some codes.
2.28 -- Added APIs for Android/iOS apps, fixed bricking system reset, updated translation, added media server tag, disabled hotspot feedback, optimised some threads.
