dsnyder
I'm joining late, but in case your question has not already been answered, I can share my experience. While I don't have your DAC, the one I'm using supports 32-bit, 768 kHz PCM and DSD512. I have no problems with these rates using VitOS for Raspberry Pi 4, however, the ZEN Stream fails to function for PCM rates above 384 kHz and, because the Linux kernel iFi chose is 2.5 years old, it does not support native DSD for my newer DACs. As a result, via the ZEN, I'm limited to DSD128.I checked the online documentation, but could not find information on which DACs are supported (or which are not supported) at the USB output of the Zen Streamer.
My DAC is a T+A DAC8 DSD. I tested Volumio installed on Raspberry Pi4 with this DAC (connection via USB 2.0), it worked only partially: PCM output was possible up to 24/352, but DSD files (DSD64 and 128) were output as 24/352 PCM as well (or 32/352, the DAC display only shows the sample rate of the incoming signal).
The T+A DAC8 DSD has two seperate circuits for PCM and DSD signal, so only the PCM part was in use when fed from the Volumio player. With PC playback, the DAC circuit is switched automatically between PCM and DSD.
How would this DAC work with the Zen Streamer?
Thanks
Practically speaking, these are not huge issues, however, this is a bit disappointing for a $399 streamer when a $75 Raspberry Pi does not have these limitations. Of course, the ZEN sounds better at the rates it does support, so there's that.
