iFi audio ZEN DAC - EISA Award Winner 'Best Value DAC 2020-21!
Aug 2, 2020 at 7:40 AM Post #526 of 1,162
Sourcing a reliable 4.4. pentaconn cable may prove problematic (I am in the UK) at the moment. It will be interesting to here reviewers’ comments if they are able to compare hooking the Zen Can & Zen Dac via RCA with the balanced option.
Aug 2, 2020 at 7:52 AM Post #527 of 1,162
I have to do that... but I need to connect the speakers rca cable in ZEN DAC or in ZEN CAN? I think ZEN DAC...
Aug 2, 2020 at 8:08 AM Post #528 of 1,162
You could try mailing Ghent audio https://www.ghentaudio.com/ they made several custom made cables for me in the past, always properly terminated
ships from China though.
Aug 2, 2020 at 4:30 PM Post #529 of 1,162
Wow! @iFi audio question, if the input on Zen Can is SE RCA will the 4.4 Bal be working?
Yes, it will work. ZEN CAN will internally turn single-ended signal into balanced, and then it goes either to a regular output or a headphone output.
Aug 3, 2020 at 10:52 AM Post #532 of 1,162
Hi @iFi audio. Just to clarify. Using the RCA connections between the Zen Can & Zen Dac will give exactly the same performance as connecting the the two units via the 4.4mm balanced connections?
Isn't the DAC performing the digital to analogue conversion so it's an analogue signal going from the DAC to the CAN.
Here's a crappy picture of mine that just came today.
Aug 3, 2020 at 12:16 PM Post #534 of 1,162
... I don't think so, rca is unbalanced
Is possible a back photo?
Aug 3, 2020 at 12:31 PM Post #535 of 1,162
@vonbonds Does your new Zen-Can output sound any different to your Zen-Dac headphone output ??
I’m not good at describing subtle differences. I do think it sounds more immersive with the 3D setting enabled. Without that I can’t tell a difference personally with my Beyer T1.2. I haven’t tried my Fostex cans yet but I assume it’ll be the same.
Aug 3, 2020 at 1:18 PM Post #537 of 1,162
I was hoping the difference would be noticeable - particularly on the Beyer T1.2 as they are 600Ω ohms and technically the Zen-Dac doesn't have enough power to drive them properly. Is your balanced cable for the T1.2 ??
Aug 3, 2020 at 2:25 PM Post #538 of 1,162
Correct, for my T1.2’s. I find the Zen DAC plenty powerful enough for them personally. I don’t listen to anything obscenely loud though.
I mainly got this as I’m hoping iFi comes out with a Zen DAC-ONLY model..lol. I’d love a family related product to have the three main inputs as seen on higher end DACs.
The Zen DAC is the perfect device for a computer in my opinion. I’d love a stand alone DAC for my sitting room with my Raspberry-Pi streamer feeding it music.
Aug 3, 2020 at 2:51 PM Post #539 of 1,162
Ah, Okay, I guess with the extra power from the 4.4mm Balanced connection the Zen-Dac can actually drive 600Ω ohm headphones.
(Single-Ended) 230mw @32 Ohm , 3.3V@600 Ohm
(Balanced) 330mw @32 Ohm , 6.6V@600 Ohm
I see even the new iFi Dac Signature still only has USB input.
iFi Dac Signature
Aug 3, 2020 at 4:08 PM Post #540 of 1,162
I'll get back to you on this one shortly.
Yes, by design ZEN series DACs have only this one digital input.
There's Drop ZEN Signature :sunglasses:
Best I could do. I used the supplied RCA cables but I pulled them up to hopefully give the best view of the rear.
Thanks for that!
