The ZEN DAC or ZEN CAN could lead the magneto planar Hifiman Sundara or Sennheiser hd 660 s? Thanks
iFi audio ZEN DAC - EISA Award Winner 'Best Value DAC 2020-21!
- Thread starter iFi audio
vonbonds
- Nov 26, 2010
I couldn't find a single 4.4mm interconnect on Amazon much less a reasonably priced oneIs a reasonably priced 4mm to 4mm balanced cable going to be available?
vonbonds
- Nov 26, 2010
The Zen CAN will be powerful enough for anything. I don't know about the Zen DAC but it powers my Beyer T1.2 and Fostex TH-X00 mahogony headphones easily.The ZEN DAC or ZEN CAN could lead the magneto planar Hifiman Sundara or Sennheiser hd 660 s? Thanks
- Jan 15, 2015
Drop has such interconnect as add-on if you buy the iFi 6xx signature edition amp.I couldn't find a single 4.4mm interconnect on Amazon much less a reasonably priced one
Reasonably priced? I believe it is $90, so you'll be the judge of that
vonbonds
- Nov 26, 2010
The Drop is closed so I'm getting the "regular" Zen CAN to pair with my Zen DAC. Also $90..LOL..F thatDrop has such interconnect as add-on if you buy the iFi 6xx signature edition amp.
The same... but 90 usd... It's absurdThe Drop is closed so I'm getting the "regular" Zen CAN to pair with my Zen DAC. Also $90..LOL..F that
OK, thanks. But, after that, where could I connect the speakers, via RCA? In ZEN DAC or ZEN CAN?The best way would be to go from ZEN DAC's (with its outputs fixed, not variable) 4.4mm balanced out to ZEN CAN's 4.4mm balanced in.
Yes, the 4.4 to 4.4 adapter is currently out of stock on Amazon, but you could purchase a 4.4mm to 2.5mm adapter and get a 2.5mm female to 4.4mm male adapter to make it work. Total would be under $35 from Amazon.
- Jan 15, 2015
I recommend contacting custom cable makers, and ask for a quote...Yes, the 4.4 to 4.4 adapter is currently out of stock on Amazon, but you could purchase a 4.4mm to 2.5mm adapter and get a 2.5mm female to 4.4mm male adapter to make it work. Total would be under $35 from Amazon.
2 that I have worked with and highly recommend:
* Triton Audio Cables (https://tritonaudiocables.com/)
* Hart Audio Cables (https://hartaudiocables.com/)
I think so far, seems USB is preferred
Is this still the case? Thinking of getting an external power supply for my Zen.
Too expensive!I recommend contacting custom cable makers, and ask for a quote...
Great idea - did you actually see the 2 specific adapters for $35 - I can't find them on Amazon ??Yes, the 4.4 to 4.4 adapter is currently out of stock on Amazon, but you could purchase a 4.4mm to 2.5mm adapter and get a 2.5mm female to 4.4mm male adapter to make it work. Total would be under $35 from Amazon.
I did find this on AliExpress for $24 but shipping would be 2 weeks.
►https://AliExpress.com/item/4000933941566.html
4.4mm to 2.5mm male adapter:
https://www.amazon.com/dp/B08278J9NX/ref=cm_sw_r_cp_apa_i_-mIjFb8P0V393
2.5mm female to 4.4mm male adapter:
https://www.amazon.com/dp/B0751B7PTS/ref=cm_sw_r_cp_apa_i_4oIjFbJYCD3J0
Mmmm, bad quality I thinkGreat idea - did you actually see the 2 specific adapters for $35 - I can't find them on Amazon ??
Baten
- Sep 13, 2012
This one looks pretty goodGreat idea - did you actually see the 2 specific adapters for $35 - I can't find them on Amazon ??
Second one has terrible reviews! might not even be balanced!4.4mm to 2.5mm male adapter:
Total: 6 (members: 0, guests: 6)
