I am stacking my xdsd with a pioneer XDP-30R that can output DSD via usb, so the player is just a transport. .....
Cheers.
Where does one find the DSD Out on/off?
Cheers.
You hold down the effects button when powering up.
Thanks Buddy !!
I thought I'd throw this in there, straight from the manual as there is a warning.
As the xDSD
retains the last mode on next power on, it will revert back to Line
Output mode if that was the last mode used.
Thank you that is very conscientious. I had read that in the online manual. I am planning on using it as a DSD Transport only.
And at the risk of sounding like a complete nincompoop, By the Effects button do you mean the "Lineout" button"? and how do you know where it is before you turn it on in order to hold it? Unless this is a different button you are talking about. Just so you know I wont have the 30R until Friday so maybe when I receive it it will be obvious, but at this point I dont see "effects"-button in the online manual.
Thank you,
T
It's the button to the right of the 3D / Xbass on the xDSD, to the right of the power button/volume cog it has a settings/Bluetooth symbol directly above it.
Thank you,
T
Ahh epic fail, do not use forum and work at the same time apologies for confusion
https://www.amazon.com/Hi-end-Silver-Balanced-Adapter-Headphone/dp/B07FJNHMMT
I recently ordered this - I assumed that the 3.5 TRRS was what I needed, is it possible that the left and right might be different?
I'm not going to cause damage using this?
I can confirm this one definitely works for my XBA-Z5 with Sony 4.4mm balanced cable. The quality so far seems good enough, although since I received it I just haven't had time to sit down and listen to music much.Did this work? I have Sennheiser 660s which came with a balanced 4.4mm Pentaconn cable.
Can anyone suggest a tried and tested 4.4 female to 3.5 male, so I can use the xDSD balanced?
Thanks
You're in for a treat with the balanced output.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
