iFi audio xDSD- The Official Thread
Dec 26, 2018 at 5:28 PM Post #1,171 of 2,506
I have just listened Spotify standard streaming (96kbps) which I never tried before. xDSD bluetooth (AAC codec) is much better than direct plug in to iphone even though such low bitrate source. I could easily notice lower noise floor, wider dynamic range etc within 5 seconds. Probably you may have issue around your power amp or Samsung note 9 (not sure hardware or software).
I will try the unit again and do some critical listening. I also read that the Exynos version of the note 9 has a good DAC. So that's something to consider I suppose. I got the below reply from IFI for the issue
'First, we do recommend that the unit is burnt in to get the best sonics.
However, the Bluetooth in the xDSD has 4 chips:
1) BT receiving
2) Reclock
3) DAC
4) Amplifier
So each chip does 1 job - whilst normal Bluetooth does stages 1/3/4 in 1 chip.
So the BT in the xDSD will be better than normal Bluetooth, however there is around 10% quality loss with Bluetooth compared to normal Bluetooth (30%), wired connection will be better as there is no quality loss.
So if you compared BT (xDSD) to wired (S9) they will probably be 'on-par' with each other. Though the xDSD does some amplification a little better as its pure analogue compared to the S9.
If you did wired from USB output (S9) into the xDSD you should hear a bigger jump in terms of sonics.
Though audio is subjective, there is no right or wrong - its your ears which are the judge'.
Dec 26, 2018 at 5:31 PM Post #1,172 of 2,506
1) BT receiving
2) Reclock
3) DAC
4) Amplifier
Nice. Yeah let us know.
When I use my xDSD, I always do phone to xDSD via BT, and xDSD is connected via cable to my headphones. I don't think you can connect the xDSD to headphones via BT anyway. So I just refer to that as a "semi-wireless" setup.
Dec 26, 2018 at 6:41 PM Post #1,174 of 2,506
Can the new iPad Pro with USB-C connection just plug straight into this?
Yes, but DSD and MQA isn't working, and it displays it as a headphone rather then a USB Device. Mulitple threads on roon forum about it.
Dec 27, 2018 at 7:44 AM Post #1,175 of 2,506
Dec 28, 2018 at 3:16 PM Post #1,176 of 2,506
iFi audio – The 2018 Summary
It’s been quite the year…
Dear community,
2018 is coming to an end and we’ve decided to use this occasion to share with all of you good people a word or two. Many of our product ideas were developed from what you had to say, so we’re extremely grateful for your support. You’re the fuel to our fire, thank you!
The end of the year is also a good time to summarize what we were able to achieve in the last 12 months. Without further ado, here’s what we did:
Hardware
March – xDSD
Before this product came to be, we knew that we had to develop something very different from what we’d done before. We thought about many things – toasters with built-in speakers, a wind-up DAC for use in the dessert…only kidding! We aimed for a portable device with wireless functionality as good as a wired connection, improved volume control and a new look. Suffice to say, we strongly believe that with xDSD we were able to deliver on all counts. The toaster has had to wait!
May - Pro iDSD
The Pro iDSD is the most ambitious and complex product of ours to date. It started many years ago as a rather simple machine, but the more time passed, the more advanced it became. After years of suffering (and here we mean both ours AND yours, just take poor Curtis as an example), the Pro iDSD eventually came into being as a state-of-the-art desktop platform loaded with so many features that it's far easier to list things it doesn't do! Not only this, but the Pro iDSD also has A LOT in common with AMR's upcoming Diablo DAC. The former is actually a scaled down version of the latter and we're exceptionally proud of how it turned out.
June - iFi OTG Cable
We released this item due to huge demand. It's reliable, affordable, looks sleek and there's no rocket science behind it. It does the job where it should. It's useful. Hey, if we're capable of delivering headphone amps and DACs, who said that we can't make a quality OTG cable? And nope, before anyone asks, we can’t make the equivalent Apple cable – if we could, we (and the rest of the world) surely would!!! Sadly, Apple don’t share the tech that we’d need to make one work. Would you, if you were Apple?
June - DC iPurifier2
All our iPurifiers were developed to show that even a small and affordable item can really improve sound quality if backed by solid tech. The iPurifier2 is a step up over previous versions of this product, simply because our in-house developed circuitry got better over time. Practice makes perfect!
· July - iPurifier3.0
USB sorters have always been of utmost importance to us and the iPurifier3.0 shows our attitude towards these items. This product might look nothing like our nano or micro iUSB3.0 machines, but its roots are the very same. It was designed to audibly improve the USB interface and very positive feedback from you guys out there showed us that it does just that! Thank goodness!
October – xCAN
Yet again X marked the spot in October! We really looked forward to releasing the xCAN. On the surface, it resembles our xDSD; they have similar set of features and they look very much alike, but the differences end there. Yes, each has finely implemented Bluetooth receiver, DAC and headphone amp in one neat enclosure BUT the xCAN is a portable and fully analogue amplifier above ALL else and its D/A conversion option is a cherry on top, whereas the xDSD - a DAC in the first place - is the exact opposite. Plus these two can work as a team and we have photographic evidence from you guys to prove it!
November - Ear Plugs
This one you didn't expect, huh? Us neither. But then again, we like silence and it’s yet another way to give you guys a low noise floor! (Plus they can protect your ears from the squeaks of protest when your loved one finds out you’ve bought yet another piece of audio equipment!) We try to think of everything…
Software
March - MQA firmware for all nano and micro products
This firmware was one of the most important things for us in 2018. We didn't want to include MQA functionality in just one or two products, we wanted to roll things out across all suitable iFi goods, even some discontinued models. Even though the 5.30 'Cookies & Cream' firmware has some limitations, this is the one to go after if you'd like to listen to MQA regardless of the iFi audio DAC you use.
October - GTO filter firmware for all nano and micro products
The GTO filter was a tricky thing to develop, but in the end, it surely was worth the effort. To our ears it sounds amazing enough to surpass every other filter out there and we encourage everyone to give this one a try. Hey, it comes at nil cost, improves sound and if you don't like it, you can always use our previously released firmware. That's a win-win right there.
November - Beta MQA firmware for the Pro iDSD
Fully operational MQA on our Pro iDSD took us a fair bit longer than expected for a reason. (Poor Curtis was turning in his grave!). The amount of work needed in order to have this signal fully decoded was nothing short of staggering. Everything had to be coded from scratch. Both our team and MQA's engineers were involved in this project and we're ecstatic that we were able to finally have this functionality ready. Enjoy!
Additionally, one thing we’re very proud of is that we were able to push our head of sales out of the UK office for well-deserved holiday. Blindfolded, the man was in shock and had no idea where he was transported. Since no laptops or comms with his team were allowed, after the adventure he told us that withdrawal shivers kicked in hard. But once he got off the plane and acknowledged he was in Iceland… Long story’s short, after this trip he returned as a new man. Even though he’s a good lad, we didn’t miss him at all but shhh…
Dec 28, 2018 at 4:43 PM Post #1,177 of 2,506
Dear community,
Hardware
March – xDSD
May - Pro iDSD
October – xCAN
Software
Hi
The firmware page on IFI website says the 5.30c firmware contains bug fixes and the GTO FILTER which apparently only applies to USB inputs. I have a xDSD with the 5.30 firmware. If I'm only planning on using the xdsd via Bluetooth would I not get the benefit of the GTO filter? Would it be worth updating the firmware for the bug fixes? Thanks
Dec 29, 2018 at 12:41 PM Post #1,179 of 2,506
Dear community,
Hardware
March – xDSD
May - Pro iDSD
October – xCAN
Software
A VERY productive year, iFi!! :L3000::thumbsup:
Dec 30, 2018 at 4:49 PM Post #1,180 of 2,506
Hi
Yes, our GTO works only via USB input and if you use your xDSD via BT only, you can stay with your current firmware.
Dec 30, 2018 at 4:51 PM Post #1,181 of 2,506
So I am assuming since it's USB this affects iOS and the CCK too? :thinking:
Edit: Holy dyslexia Batman! I read GTO as OTG....wow. Literally still sipping on my morning coffee... Updated successfully in macOS! :sweat_smile:
Dec 30, 2018 at 5:33 PM Post #1,184 of 2,506
@iFi audio I have a question. Is this due to hardware or firmware, and if the latter can this be fixed with an update? Most USB DACs, including the iDAC the L/R balance can be adjusted in Audio Midi Setup yet the xDSD this is locked out. I would really love to adjust System wide balance again.
Dec 31, 2018 at 4:03 AM Post #1,185 of 2,506
Firmware related. We purposely locked digital volume control.
