Mightygrey
Hey mate, I'd be going from memory so couldn't reliably tell you. I wouldn't really recommend buying both as a stack as it'd be a waste of the xDSD's talents, and it not that usable in terms of form-factor. The only real sonic difference would be sound pressure level, and the ability to drive less sensitive headphones with the xCAN.I know it may have been a while since you returned the review units, but could you share any further thoughts on the xDSD + xCAN stack? Is there a notable difference in sound from either unit alone? I’m guessing you had the xDSD set to line out mode, to bypass the xDSD amp section and try to get the best of both worlds with the xDSD DAC section + xCAN amp section. Just wondering if there’s any difference in sound other than just more power.
