- Mar 20, 2013
Make sure you have the NEO Stream set to USB output, and not Digital or analog. When the DAC is connected and powered on it should be an option in the Menu.Can somebody explain how the digital out is supposed to work? My intended use: upsampling to dsd512 with audirvana, send it to the Neo Stream with upnp and then with dsd direct send it via digital out to my T+A dac200 with usb. USB is the only hi-res input on the dac200. I tried it out, but the dac gives “no signal”, so probably the Neo Stream is one bridge to far…
Digital is for all the other outputs, coax, etc.
Hope this helps.
Cheers!!
Stay updated on iFi audio at their sponsor profile on Head-Fi.
