john57
- Feb 16, 2009
USB 3.Optical Cable by Corning is interesting. It has a bandwidth of 5Gb/s between the end points. It does require 5v available on the USB ends for the convertors.
the cable gets 5v at both ends... at the computer usb connector and then at the receiving device usb connector...
but no power within the cable run... so the cable acts as a filter of noise
with the idsd Nano or Micro being stand alone battery power allows the cable to work with these ...
i have an opinion to make...
wishing ifi would just make the idsd/ifi nano to just connect the lightning usb directly between the igadgets and the nano.
This is happen with the micro iDSD to connect diretly you lightning USB cable without a short USB type B adapter. Sadly that the nano iDSD has a USB type B port instead of a type A like the micro iDSD.
Why? So they could stop me from using it with my PC, or with my Android phone?
that's not what i meant.
i mean it would be great if we could just use a simple usb to connect it via any phone.
for mobility. for portability. without the hassle of using many connections and long wires.
to keep it simple and small.
The only issue with using USB B, is the lack of availability of a decent lead. There's a huge gap in the market for USB B to Micro USB and Lightening. I don't know about the technical aspect but there must be a reason for using USB B, most if not all DACs do use USB B.
yeah.
how i wish there would be options... out there.
From looking a USB cables, I am interested in the A&B Systems one as it splits power and data. However, after more reading it seems all USB cables have 4 conductors, 2 for data and 2 for power, so what does the A&B one do that they don't?
