iFi Audio Nano iDSD discussion + impression
Oct 23, 2014 at 1:56 PM Post #901 of 2,063
Thanks for your reply. It is not that the pdf is incorrect, it is just that it is a little tone deaf. Since I must have followed those instructions to get any kind of DSD running in the first place.  I have 64 DSD up and running. I just can't get 256 DSD running. I was wondering if anyone else has and then to see if their setup is different from mine. Since I have now tried it on two PCs which both run 64 DSD fine, I am wondering if it is even possible to get foobar to do the higher rate. Have you guys tried it?
Foobar has been not only stable for me, but so much less bloated the jriver which I found a lot of problems with. But I haven't tried it for two years so maybe I will give it another whirl. But honestly I was just downloading some free DSD tracks to see if I could hear a difference with 256 DSD. And I actually probably won't change from Foobar because right now it plays everything I have purchased. :)
So Has Anybody Got Foobar to Work with 256 DSD?
Yes no problem with foobar2000:
DSD256 (with Magenta led ligth on)
Follow this guide: http://www.audiostream.com/content/how-play-dsd-file-using-foobar2000
Oct 24, 2014 at 6:21 AM Post #902 of 2,063
Public Release – 2 x David Elias DSD tracks
Click here:
http://ifi-audio.com/audio_blog/public-release-2-x-david-elias-dsd-tracks/
Following on from the iFi iCLUB DSD album last week, as promised, the following two tracks are available to all.
As with the previous recordings, these are all 100% DSD, having been recorded, mixed and mastered directly on the Sony Sonoma DSD Workstation provided by Gus Skinas at SuperAudioCenter.com.
We hope you like them.
Thank you again to David for his great work on the DSD recording front!
Oct 24, 2014 at 12:06 PM Post #903 of 2,063
If your install still fails to work at DSD256, try "full" un-install and re-install. It happened to me and I got it back up and running properly. It does say this in the pdf (if you and I have the same version). I hope you appreciate the fact that Foobar isn't written by them but they are trying to help others get better sound by offering this tutorial and support. As OP says, it works for me too. Good luck.
Oct 24, 2014 at 1:14 PM Post #904 of 2,063
Here is some more instructions to get foobar2000 to work with 256 DSD... a couple changes to the pdf that was posted earlier..
If you go by the directions I would be surprised if you could get Foobar to work with 256 DSD...
in the pdf file at step 11... as shown below :
10. Open Foobar2000
11. Select Components.
12. Select Playback > Output > ASIO.
Try this instead...  should work for you.
10 Open Foobar2000
11. Select File -> Preferences -> Components
12. In the right side panel select ->  Install
13. Navigate to the Foobar2000 Components directory ( C:\Program Files (x86) -> Foobar2000->components
14 Select foo_out_asio and foo_input_sacd,   then select " apply "
15. Close Foobar2000 and open Foobar2000 again
16. Select File-> Preferences -> select Output-> select ASIO -> select Use 64bit and Run with high process priority
17. Note that the ifi (by AMR) HD USB Audio is listed as a ASIO Driver
18. Select OK
Restart Foobar2000 and use as normal...  should work
Oct 24, 2014 at 1:19 PM Post #905 of 2,063
Just in case you need a couple 256 DSD files to test your ifi nano/micro then here is a site for you....    wonder why ifi doesn't provide their own test files ??  Sure would help....
https://justlisten.nativedsd.com/albums/just-listen-1-compilation
Oct 24, 2014 at 1:34 PM Post #906 of 2,063
Oct 25, 2014 at 4:26 AM Post #908 of 2,063
Hi all,
For a quick reference quick, these are the most common areas to check that things are setup correctly otherwise DSD playback will be patchy.
Just verify that these two sections are correct.
Enjoy and most important of all, enjoy the tunes.
Oct 27, 2014 at 6:40 AM Post #909 of 2,063
  Not much is known at this point except that (1) it is the first of Nano series, hence it will be smaller than the current Micro series. (2) It will decode DSD, thus the name iDSD. and (3) it could be priced as low as $160 or so (unconfirmed yet). (4) As you can see on the picture, it will have RCA line-out and a headphone-out. It will be officially announced on the Oct. 12th @ Beijing International Hi-Fi show
Also there is mention of possible portable amp released under the Nano series in the future.
Why two RCA lines out on a small thingy like that, why no 3.5mm out ?
Oct 27, 2014 at 12:53 PM Post #910 of 2,063
There is a 3.5mm out. The RCA is addtional, like connect with a normal RCA cable to an external amp or other device. 3.5mm and RCA are using the same internal lines, so there is no difference. Choose what you prefer.
Oct 27, 2014 at 9:16 PM Post #911 of 2,063
I think it is a Digital Output, not a 3.5mm output.
Oct 27, 2014 at 9:31 PM Post #912 of 2,063
There is a single RCA digital-out (S/PDIF) on back, two analog RCA out on the front for stereo channels. There is a 3.5mm headphone-out on the front as well.
Oct 29, 2014 at 3:30 PM Post #914 of 2,063
Just listening Yahel from iDSD on my XBA-C10, and it sounds pretty amazing. Recently I leave Alpha Dogs and Pan Am at home, because iDSD + XBA-C10 is really great combo, and truly portable. Amazing how much detail these tiny earpieces provide, but only when driven by iDSD. This device is great achievement of iFi's - honestly, and I'm only listening to Vorbis @ 300kbps, and not DSD not even hi-rez, just HQ Vorbis. I think iDSD is truly about quality and not only features like probably other contestants might be... Now I'm thinking maybe to buy some iPhone or Android to use iDSD on the go :rolleyes:
Oct 31, 2014 at 4:55 PM Post #915 of 2,063
Hey thanks to all for the advice and encouragement, I got 256 DSD  working. Not sure what was wrong, but I ended up uninstalling and re-installing foobar and the components following dixter's mod of the audiostream instructions.
Happily listening to 256 DSD and gazing at a magenta light as I write this.
