The only way I can get my Nano to fully charge is with some high amps on the charging side (I use a Sony CycleEnergy battery pack) it does 3.6amp max at 5v. It still takes it some hours to charge from dead. Most of the time, a top off takes less than an hour, and the pack will sense when charge is complete and shut off. From my experience, the laptop USB port will never fully charge the battery. No biggie. I'm just happy as **** about how good the Nano sounds with battery.
On another topic re. said Nano. I did some experimenting today with my new Led Zeppelin remasters. First of all - the Zep 1,2,3 albums are of course legendary, but they were also recorded loud, distorted (over-driven tubes of course) and pretty damn close to clipping, but back in the analog days its all good. Its that 'live' sound that everyone was wanting to capture on their record. That kind of distortion does not translate well in digital.
Specifically on Led Zep ll, track 2 'What is and what Should never be", at about 1min 15sec into it when the song starts gettin it done, there is tons of 'effects' all hitting your ears at the same time (reverb, fuzz, tube distortion, what could be bass clipping, etc), I mean Jimmy Page can chime in here, its a balls to the walls recording.
So, I was a bit blown away by how good it sounded, but I was having a little trouble 'sorting it all out' so to speak. It sounded a wee bit 'off' when it all got a bit loud and crazy. Thats always a good opportunity to play with the software, hardware etc. That way I can focus on the exact sound(s) that are tweaking me. So the albums are redbood, ripped to WAV to my laptop, and I'm using JRiver 19. So I flipped back and forth between playing it native, to using JRiver to upsample first in PCM to the max sample rate 352,800khz, then to 4xDSD.
Upsampling PCM to higher rates did not provide a noticable difference, in terms of the particular sound that I was focusing on. The 4xDSD did. Not 'huge', but a smidgin more 'believable', and a bit more like what I would expect to hear with a good vinyl rendition. - So there you go. Check for yourselves.
