Hi, should I get the nano iDSD Black Label or the Hip-Dac, wich one has the best sound ? why the Hip-Dac has one ouput for charging and one output for data and the nano iDSD Black Label has only one input (data/charge) ? cheers
Got a question I just bought the Nano black Hip dacs not available is the hip DAC sound any different than the Nano? Does it have more power than the Nano? Are they using the same Burr Brown chip?
I currently have the Nano sounds pretty good. Pretty good power but I hear a lot of good things about the hip DAC witch you can't even get right now it's sold out everywhere the Nanos a little bit on the thick side to be putting on the backside of a phone that's why I was considering the hip DAC.
Can anyone show me the picture of TRRS Balanced 3.5mm wiring to use with iFi Nano iDSD BL?
And also can I use Balanced TRRS with both IEMatch and Direct 3.5mm or just IEMatch?
Thanks.
Example: Is this correct? I want to build an adapter to 2.5mm balanced R-R+L+L-
Thanks for the reply iFi.
Actually I already have the pdf but still not sure L+ R+ L- R- for wiring (No Left, Right in the picture) ... So I assume that the picture mean like this? TRRS = L+ L- R+ R- ? or else?
