johncarm
- Jun 27, 2014
My question is about comparing the short USB 3.0 cable that comes with the iUSB3.0, which presumably is not a premium cable (it wouldn't make sense for iFi to put a lot of money into the included cable) to a premium USB 2.0 cable, in particular the Gemini or Mercury.
I already compared the included USB 3.0 cable to a Cardas Clear, and the included cable was far better. I am not sure what factor is most important. The Cardas was a 2.0 cable, it was much longer, and maybe it's just not a great cable.
Isn't the Gemini usable between the laptop and the iUSB3.0? It would need to be plugged into two of my laptop ports. It seems to me it would still be keeping the data lines separate. Of course, you can debate whether the cable on the input side of the iUSB should make a difference. The iUSB3.0 regenerates the USB data and theoretically would be pretty insensitive to its input data quality. But as I said above, at least cable on the input side of the iUSB3.0 was clearly inferior.
Regarding the quality of my system downstream from the iUSB3.0, my DAC and amp are very good. My DAC is the Nano, but it has a custom modded power supply internally and some RF control. The amp is a custom 12AU7/MOSFET hybrid with an over-the-top power supply. My headphones are the Senneheiser HD650 which are a great match for the amp (in fact, in my experience, they are a great match for a number of different 12AU7/MOSFET hybrids).
John
John
