A very interesting results, especially for Mytek Brooklyn DAC+. Since I have Mytek Brooklyn Bridge which as you all probably know is DAC+ with added streaming capabilities I've decided to do some tests on my own. The reason for it was the fact that I’ve been comparing Mytek and Hugo TT2 USB inputs recently among few others DACs, and decided that both DACs are doing great job when using USB input and none of them requires any USB filtering/isolation gimmicks.
While I do not have iSilencer Plus it happens I have both iGalvanic and iUSB. I’ve disconnected Mytek from my notekbook docking station and connected Mytek to nano iGalvanic3 and micro iUSB3 and I've done 2 listening sessions (1,5h each) during weekend to make sure that results are repeatable. The testing methodology was as follows:
- Running Audirvana with upsampling to DSD256 playing from FLAC files when connected to notebooks docking station
- Running Audirvana with upsampling to DSD256 playing from FLAC files when connected to my i7 notebook directly
- Running Audirvana with upsampling disabled playing from FLAC files when connected to notebooks docking station
- Running Audirvana with upsampling disabled playing from FLAC files when connected to my i7 notebook directly
- Running Audirvana with upsampling to DSD256 playing from FLAC files when connected to iGalvanic and iUSB
- Running Audirvana with upsampling disabled playing from FLAC files when connected to iGalvanic and iUSB
Some additional notes:
- micro iUSB3.0 USB Power switch set to Auto, IsoGround enabled
- nano iGalvanic3.0 Ground Link set to Full Isolation (center position)
- notebook has been running using PSU with battery/cpu power saving features disabled
- Mytek has been running on stock PSU cable without external PSU
- Mytek MQA filter has been disabled, all other filters left in default state as advised by manufacture
- Standard USB cables included with particular products from Mytek and iFi has been used
- Both full size cans and IEMs has been used
Results: I found no audible sound quality improvement when using additional USB filtering. In fact I am even almost convinced it degraded sound quality in some cases. The most possible cases for possible sound degradation I’ve found in my library are following albums: Tsuyoshi Yamamoto Trio – Autumn In Seattle; (by the same Trio) Misty. Since I have no way to test it to prove it I will stick to the opinion that there is no audible impact on sound quality at the best case (or at least I can not hear it).
One more note: if your results are repeatable I guess it would be fair to update your Mytek Brooklyn DAC+ review stating that dac usb isolation/filtering is not perfect as it seems (while I have quite opposite experience). On the other hand I find it odd that Mytek manufacturer states that external PSU can improve sound but does not mention any usb filtering at the same time in user manual.
There is another interesting thing to test: how does nano iGalvanic3.0 with micro iUSB3.0 stack up against iSilencer Plus, after all iSilencer Plus is newer product.
