Hey guys/iFi,
I have been looking at most of the posts in this thread and it seems that no one has tested these products with a setup that is geared for
both PC gaming and audio/audio production, or at least it looks as if no one has tested the product(s) when in-game on a PC (ie GFX card and CPU usage increase power-draw significantly);
I am/have been using the following, and suspect the problem to be not limited to just a ground-loop?:
1. PC with USB powered DAC (audient EVO 4) feeding via TRS, 2x Fluid F5 active studio monitors
2. The USB DAC also feeds my HD650 headphones
3. I was previously using an ASUS STX internal soundcard (for 6-7 years) feeding the F5s (only had for around 4 years) and HD650s
4. PC, PC monitor, studio monitors all plugged into the same power strip
.. the studio monitors pick up what seems to be exactly the same 'sounds'/interference/buzzing/electrical squealing when I use
either the
internal STX sound card or the
external EVO 4 USB powered DAC whether I am using the PC in-game or just browsing the web, however the headphones pick up no audible interference, etc, on either configuration - yet the studio monitors will continue to buzz/squeal/whine or whatever it is they love to do, whenever I am in either desktop on the PC or gaming; the F5s buzz etc whether they are being used for playback or not, ie if the headphones are plugged in on the EVO 4 it is by design meant to (which is does) re-route the sound to the headphones/cut sound from any speakers plugged in, however the buzzing continues whether this config is used or not.
So basically I am wondering if an iDefender 3(+), with the iPower plugged into the side to feed the EVO 4 USB DAC, will eliminate this issue (or issues for that matter)?
I have attached some audio examples of different usage scenarios for my setup (yes, that
lowish-sounding motorbike-like noise in the Parkitect file is
not the sounds being produced from the game itself, this is either a ground-loop issue and/or electrical interference as far as my understanding goes - I lower the volume using Windows at around 35s into the file so you can hear this);
Notice how the buzzing/squealing is constant and just more or less
unbearable when in-game as opposed to desktop use.
[ The in-game audio files have moments of no 'buzzing' - I may have lowered the volume on the studio monitors to isolate the 'noise' they produce or the game may be loading (ie not much gfx card/cpu power draw) ]
[ If you have listened to the horrendous sounds coming from the studio monitors in the attached files, you can be sure that I do not use anything but headphones to game on,as they have no buzzing or anything electrical-sounding or interference coming out. The noises made by the F5s are just ridiculous and basically are intolerable, even if the faders on the front of the F5s are on the lowest setting usable. Non in-game use for the F5s is tolerable, ie, music or video playback as the noise isn't so bad, see 'Non in-game use' file ]
Non in-game use
In-game, Path of Exile
In-game, Parkitect
EDIT: I stated that using headphones (HD650s in my case) out of the headphone jack from the EVO4 had no buzzing or interferance - I had to turn the F5s completely off in-game to make sure I wasn't hearing things, but I am actually getting the same 'sounds' through the headphones/headphones jack as the studio monitors, although it is so faint even at very low audio settings in-game, it isn't an issue.
Tempted to buy the defender 3+ with ipower or even something like the igalvanic, or DAC from ifi that can get this issue resolved, but unsure of what route to go down (cheapest would be preferable, lol).
