Has anyone ever used an external battery pack like those for smart phone charging to supply the USB converters/isolators like iFi products (e.g. idefender) etc..? I read some people used for lower power DACs. I am thinking if one does not wish to invest a LPS for every single of these 3-5 V devices, the battery may be good solution ?
Currently I am powering my idefender using ipower as recommended but I am wondering if an external battery will work better or just as good?
I also wrote a brief review of the igalvanic package on computer audiophiles:
‘I tried the iFi gal & idefender + ipower
System:
Mac air With Audirvana - via USB --> Geek Pulse DAC ---> DACware Tori junior tube amp. (note I am not using headphone but speakers, Epos floor stander)
Out of box, no burn in - straight between Mac and DAC: sound is warmer, smoother and deeper/wider sound stage, more air to sound, darker background
Comparing between my Macbook plug to AC vs running on its battery :
with AC cord - more dynamic and harder sound, sounds a bit harsh, more digital
with battery only - softer and smoother, more analogue but less dynamic, quieter and a bit too gentle, not enough meat to the sound,
I am not really satisfied with either , one too hard and one too soft. When I play without the AC cord, the dynamic is much better if I don’t use the igalvanic, but the harshness is back. There is greater air and space without the igalvanic. With igalvanic while using battery on Mac, it feels like it is muting something, like having a tube gear that is coloring something but not really improving the sound much. If I put back the AC, it is much better but there is still some degree of harshness/hard feel. So I thought adding the igalvanic while running Mac on battery is not helping much.
Maybe it really needs a separate power source from ipower to run better.
before I do that, I stick the idefender in:
mac —> idefender -> igalvanic —> DAC
On battery only - sounds much more open and more air, more dynamic no harshness added
on AC cord - the dynamics improves a bit but hard sound is coming back a bit, though not as much as before, the warmth, improved sound stage is still there and perhaps one will feel reasonably good about this by now.
However I feel without needing AC still sound more organic/analogue but I want the punch of the AC power.
So comes the ipower!
Mac —> idefender fed by ipower —> Igalvanic —> DAC
Things are much better now.
with battery: the dynamics and punch all back, like when the AC cord is there but without the harshness/digital feel etc, bass is deep, organic feel all there...
with AC - not really giving much more dynamic or power but the sound stage actually is thinner, bass is not as good, more flat, less organic; so really no advantage of having AC cord. Clarity also not as good.
i am surprised that idefender helps a lot and that despite using separate ipower to boost the idefender thus isolating the source AC power, the lack of AC power makes the whole gear so much better, probably more obvious than before.
My setting is - down - RF soft ground-link
the default causes dropout and clicks - ? Clocking issue with DAC? i suppose my DAC or the MAC is doing some clocking that is causing this issue ? Is this down setting less than optimal ? Maybe the manufacturer can comment on this ?
