gto88
- Dec 11, 2014
Firmware 7.2 is out. Updated mine.
Got the Signature to drive my Focal Stellia (35 ohm)
Noticed the following issues with Power Mode:
Almost no volume knob headroom without setting IEMatch set. I thought that with my headphones it should stay Off.
- When set to Turbo, volume is too high cannot even, slightly, move the volume knob past 10:00am (start)
setting the IEMatch to Ultra Sensitivity enables to tune the volume knob between 10:00am and 12:00pm- When set to Normal, volume is too high cannot even move the volume knob past 11:00am
setting the IEMatch to High Sensitivity enables to tune the volume knob between 10:00am and 12:00pm- With Eco things are better but it seems that the power is gone
Should it be like that?
Does IEMatch intervene with the sound quality?
So I was able to update mine to 7.2 as well and it's confirmed successful update through system information. However, I still can't play DSD512, and MQA still plays with a magenta light on the iDSD. So essentially this firmware is still functionally the same as the previous firmwares.Firmware 7.2 is out. Updated mine.
Just tried it and failed.So I was able to update mine to 7.2 as well and it's confirmed successful update through system information. However, I still can't play DSD512, and MQA still plays with a magenta light on the iDSD. So essentially this firmware is still functionally the same as the previous firmwares.
Apologise if this has been answered already. I am not sure if the 4.4 connection is fully balanced, although it is on the Diablo.
So is there any audio benefit for using the 4.4 connection? If so can I simply buy a 4.4 adapter for headphones or should I use a 4.4 balance cable?
Is there a sound quality comparison between Diablo and Signature?
thank u
It’s an MQA renderer not decoder. Having said that, I don’t think you would notice a difference between the two. If your looking for the best sound quality, stay away from MQA altogether and stream flac.Currently thinking about getting an ifi signature.
Regarding purple light: from what I read in the Diablo thread, it means that some processing was done beforehand like Tidal native app on IPhone for example has done first unfold.
Just Speculation from me.
Does someone know if ifi signature is a full MQA decoder or just renderer?
Diablo is a full decoder from what I read.
Anyone here tried the new MEST MKII?
It does not charge your phone if you have it connected properly, from the back where it says “digital input”. It charges from the side.Hi everybody, I just got my Signature, and I suspect that it starts charging once I connect it to phone, the charging led starts flashing. Is there a way to prevent the Signature from charging from phone? Thanks in advance!
