JinxDynamic
This will work great too. However I like Coaxial better than Optical cause it is more robust.Good idea I do a similar thing with this device.
And mine is pretty cheap too. 34usd on ali.
Do these devices pass MQA signal through?
Would need an Android phone/DAP (with UAPP) or iOS device and use USB to pass MQA. Have used 1) HiBy R5 with UAPP and OTG cable and 2) iPhone with CCK and both pass through MQA fine.Do these devices pass MQA signal through?
Does this mean that I cant bypass the battery anymore? That was one of the main reasons I bought it.
That cable does work to pass the MQA signal, at least on the R3 if you turn the gain to high and max out the volume. Can't see why it wouldn't with the R5.Would need an Android phone/DAP (with UAPP) or iOS device and use USB to pass MQA. Have used 1) HiBy R5 with UAPP and OTG cable and 2) iPhone with CCK and both pass through MQA fine.
Tried the HiBy R5 with the HiBy USB->Coaxial cable and it works to pass the signal, but no MQA.
You can’t bypass the battery. All power comes from the battery. The USB C port is only wired to charge the battery.
USB audio player PRO..???Sorry UAPP is an app..???
yes. https://play.google.com/store/apps/details?id=com.extreamsd.usbaudioplayerpro&hl=en&gl=USSorry UAPP is an app..???
