MarkParity
Formerly known as User9876
As @elira said the battery will last many years. The battery is very easy to replace too, just remove the end caps (8 screws) and slide the circuit board out complete with the battery. The connector is a standard one and although not officially supported there are quite a few suitable third party replacement batteries available on ebay and other places if your iFi warranty has expired.How easy would it be to replace the battery? Since there is no way to bypass the battery, I’m concerned about how many cycles it will last and how to get it serviced.
