Bob Parish
First, you have to install the iFi ASIO driver...
if you have installed ifi driver it should show as separate audio device in roon. you just need to enable it
I have the mqa core decoder set to off, what do I need to set the mqa capabilities to, renderer and decoder or just decoder?
I think that decoder + renderer is the right option. i assume decoder only is only for cases you want device only to decode mqa and send the signal to another device that is doing the final rendering. if you have headphones connected directly to diablo this is not the case.I have the mqa core decoder set to off, what do I need to set the mqa capabilities to, renderer and decoder or just decoder?
Edit: I have just read Seb's reply, so I am maybe wrong.
Even if you tell Roon that Diablo is a decoder and renderer, it will still only do the final unfold (act as a renderer) when you enable Roon's core decoder. This is the appropriate configuration any time Roon's DSP engine is to be used, such as when I want to engage the built-in Audeze filters for my LCD-X.The Diablo is a full decoder so there is no need for the renderer option! You can do either or, but our preference is to usually set the Diablo as a decoder.
CMIIW, I think because it has auto discharge when it goes up to 90%For how many hours do you guys charge your Diablo with a supplied ifi charger?
The manual says that it should be around 6 hours
I my case it is definitely less, I believe it is about 3.5-4 h.
Stay updated on iFi audio at their sponsor profile on Head-Fi.
you can turn off mqa core decoder to get full potential of diablo as it can decode itselfI found it! Def much better now. Switched over to the cookies & cream firmware. Sounds great. I'll have to try the GTO again with this roon setup, but so far I'm very impressed. Way better than just using tidal app. Soundstage & general sense of space and the clearness of vocals is impressive. Still think the GTO will be better for me but I am impressed.
Hmm, I got magenta on Diablo connected to iphone and Tidal app playing Masters.
Manual says that Magenta is Original Sample Rate* - MQB? What does that mean? It should be an mqa file.
So it should be either green or blue...strange...
